Whole Latte Love water recipe
Hello,
Awhile back, Whole Latte Love put out a video on Youtube with a very simple (to me) water recipe geared to a 1 gal bottle of distilled water. It uses baking soda and Epson salt. I use it simply because it is a very simple process which he walks you through step by step. Heck, even I could follow it!
I use this in my espresso machine. My pour over water is simply Costco bottled water.
Anyone else using the WLL recipe? Does anyone else have one gallon recipes?
I am using Dr. Pavlis recipe - adding Potassium Bicarbonate only to the water. I haven't tried anything else, so I can't compare taste.
10 gram of Potassium bicarbonate to 1000 ml of water to create concentrate. Then, add 37 ml of that concentrate to each gallon of distilled water (I use deionized water).
I wonder whether adding magnesium sulfate improves taste?
I use a similar recipe. 10g Potassium bicarbonate to 100ml of DI water. Then 4-6ml of that to a gallon. A bit easier cause I can use a medicine dropper.
I did try the Sodium + Mag version from Barista Hustle. And I never got great tastes out of it. BH has a bunch of recipes and I tried a few. The best was lowest TDS of around 50, but still Potassium only tastes better and is way easier.
Sorry I hadn't replied earlier. I'm going to have to adjust my notification settings. Yes, That is the video.
Ben and Blacktip, you both use Potassium Bicarb, but it appears to be vastly different amounts per gallon. Am I reading this correctly? I'd imagine part of this is individual taste.
Both recipes are very close. ben8jam uses 100 ml of concentrate. I use 1000 ml of concentrate.
Thanks for referring me to this thread. This seems easy enough. Is there a recommended brand you all buy potassium bicarbonate from, or is anything from the local shop and Amazon alright?ben8jam wrote:I use a similar recipe. 10g Potassium bicarbonate to 100ml of DI water. Then 4-6ml of that to a gallon. A bit easier cause I can use a medicine dropper.
