Water in North Stamford, CT
- homeburrero
I'd say stick with your water recipes.
The worst thing about this water is that it has 127 mg/L chloride. Chloride is corrosive and not easily filtered unless you resort to reverse osmosis (RO) systems. La Marzocco and others advise going to RO when water has over 30 mg/L chloride. Synesso is more conservative an advises RO when chloride is higher than 15 mg/L. Your 127 mg/L level is unusually high.
The water also has high calcium hardness and would likely be very scale prone unless softened. (84 mg/L calcium is equivalent to 210 mg/L calcium hardness as CaCO3.)
P.S.
This report is missing numbers for bicarbonate and for alkalinity, so you can't do a proper limescale risk estimation. But at that level of calcium hardness you can pretty much assume that it's very scale prone.
P.S.
Pat
