Water for La Marzocco Linea Mini and Micra
Looks like I will be upgrading to either the La Marzocco Mini or Micra here before too long. I see that there are specific water requirements which makes sense. I cannot get the brands that they advise near me though. They said I can get 3rd wave packs. I was wondering if I can use maybe a cup or so of the Crystal Geyser from NY with mostly the distilled water? With such a small amount I can't see that doing any harm? Some of the reviews for the 3rd wave were not too positive. Any thoughts from those about the water are appreciated.
- Jeff
If you can't easily get one of the "non-scaling" bottled waters, or you want to explore how different waters impact the flavor in the cup, mixing your own is straightforward. Starting with distilled, RO, or RO/DI and then one or two, readily obtainable ingredients, it is easy to mix a liter or more as you need it. Lots of options in the Water sub-forum from RPavlis' suggestions and up in complexity.
Personally, I use RO/DI from a bulk machine at a local Whole Foods and 1000 ppm equivalent concentrates for "GH" and "KH". That makes it "math-free" in the morning as 20 g of concentrate in a liter total of mix is 20 ppm.
Thanks and I will have to look into that. I have access to RO water too. Where do you get those concentrates at?
- Jeff
I use baking soda and food-grade epsom salt. There are other choices, often available in grocery stores or wine-making supply shops. I don't know that there's a "best" agreed, even for a given roast level, burr set, and machine. The good news is that it isn't too hard to get good-tasting, non-scaling water without investing in a chemistry lab. A couple of bottles and a reasonable scale that can weigh a few grams to hundredths of a gram are enough.
I make R Pavlis water by mixing .4 gram of potassium bicarbonate with one gallon distilled water. As Jeff suggested, the water forum is loaded with water advice.
Ok, cool. I think I have that from my winemaking supplies. I will check tonight but it sounds familiar to me.
