"Water For Coffee" book discussion - Page 8
Viernes
#71: Post by Viernes »
@welone
If I understand correctly what you posted, and I'm sorry to say this (if I'm wrong I apologize), then the book it's a fail, it have a big mistake. I know people who bought the book (I have it too), and they have made water with the values described in the book as ions to feed their espresso machines with the water !!
DarrenAddy
#72: Post by DarrenAddy »
I think it only fair to point out that the authors have made a "Corrections and Amendments" to Edition One available here: https://github.com/chhendon/waterforcof ... _10_15.pdf (since Oct. 15, 2015). For those concerned about copyright issues, the page on waterforcoffeebook.com containing the link above says:
Note that information contained in the corrections is freely available, and it free to share publicly without modification.
I believe that these corrections are incorporated in the the current edition (but won't be able to tell you until my copy arrives).
Baratza: skilled in the art of grinding
Sponsored by Baratza
homeburrero
#73: Post by homeburrero »
Alas, that 10-10-2015 corrigendum is old, and since then the authors have learned a bit more. Not only that the SCAA hardness and alkalinity measures are unquestionably in CaCO3 equivalent units, but also that their own ideal brew zone graphs were developed using standard GH/KH kits and the graph axes should have been labelled in conventional (archaic, they would say) CaCO3 equivalents. This was nicely explained above in the Feb 7 post from welone. The October corrigendum causes confusion because it reinforces the impression that the GH and KH units on the book's ideal brew zone graphs should be interpreted as ppm as ion (Ca++, Mg++, HCO3-) rather than in CaCO3 equivalents. The authors say they will correct that in the 2nd edition, which I thought they were still working on.
Darren:
Are you sure you have ordered a 2nd edition and not the first?
Update/addition: As of August 2016, Christopher Hendon is saying on Facebook Barista Hustle that their 2nd edition should be coming out sometime in 2017.
Pat
bdswan
#74: Post by bdswan »
So, is the General Hardness vs Carbonate Hardness chart correct as-is, but labeled with incorrect units (which should be ppm as CaCO3)?
homeburrero
#75: Post by homeburrero »
bdswan wrote:So, is the General Hardness vs Carbonate Hardness chart correct as-is, but labeled with incorrect units (which should be ppm as CaCO3)?
Yes, my understanding is that every graph in the first edition book that shows General Hardness vs Carbonate Hardness should be interpreted to have units in ppm as CaCO3 equivalents. This includes the representation of the SCAA spec as well as their own ideal and acceptable brew zone graphs.
In the Corrigendum they do have a graph of the SCAA standard plotted as general hardness vs carbonate hardness. In that particular case the graph units are in [Ca++] ion ppm on the Y axis and [HCO3-] ion ppm on the X axis.
In Chapter 6 where they are discussing recipes, they are not using ppm as CaCO3 - there they consistently express [Ca++], [Mg++] and [HCO3-] as ppm (mg/L) of the particular ion they are quantifying. They do use the terms GH and KH in that chapter, but there they are using concentration of ion rather than the conventional measurement units of GH and KH. (The conventional units of these 'hardness' measures are gpg, German degrees, French degrees, Clark degrees, mmol/L, mEq/L, or, most commonly, mg/L or ppm as CaCO3.)
Note for sticklers:
KH stands for Carbonate Hardness (in German, Karbonathärte) and strictly speaking is not the same thing as alkalinity. But they do get used interchangeably and for our purposes can be treated as the same thing. The API KH test is a total alkalinity measurement (it simply measures the acid buffering capacity of the water sample.) Also, carbonate hardness is a confusing term because it may not involve any hardness at all - a solution of sodium bicarbonate has 'carbonate hardness' but has zero general hardness. In water reports you generally see the term alkalinity instead of KH.*
GH stands for general hardness, and is a measure of the amount of divalent cations in the sample. Primarily Ca++ and Mg++. GH and 'total hardness' are the same thing. Since it is a measure of the total number of those ions, and not the weight, and since different ions have different weights, it is expressed in these equivalents that can cause confusion until you get used to them. Using the unit of ppm as CaCO3 turns out to be handy because you can divide by 100 to get mmol/L, or divide by 50 to get mEq/L. Also, if you express both GH and KH in ppm as CaCO3 units, you can subtract the KH number from the GH number to get an idea how much of your hardness is so-called permanent hardness (non-scaling hardness) and how much is so-called temporary hardness. (KH/alkalinity is an estimate of temporary hardness when the GH is higher than the KH.)
* {Later addition] And, I should point out that there are two different meanings for the term "carbonate hardness." The common one used by all the aquarium people, many of the beer and coffee people, in the wikipedia definition, and in many of the test kits is synonymous with carbonate alkalinity. It is abbreviated KH. There is an alternative definition where the term carbonate hardness is used to refer to the portion of Ca++ and Mg++ hardness that is associated with carbonates (CO3-- and HCO3-.) This definition is synonymous with "temporary hardness" as it is the portion of the total hardness that might precipitate (produce scale) under heat and pressure. The new SCAE water chart uses that definition. It is a much more sensible definition in that in this case the term simply means what it says - is the actual hardness that is associated with carbonates.
In future posts on this forum I think it best to avoid using the term carbonate hardness when alkalinity, or even when carbonate alkalinity is meant. Not sure what to do about the term KH. It's used by the popular test kits (which measure alkalinity) and is part of the vernacular in coffee water discussions. GH:KH seems to be a handy and frequent shorthand for discussing the total hardness and alkalinity of a water (i.e., a GH:KH of 100:50 is commonly used to describe a water with 100 mg/l total hardness and 50 mg/l alkalinity as CaCO3)
Pat
yakster (original poster)
#76: Post by yakster (original poster) »
Anyone using the knowledge they learned from this book to make their own custom water? I was, but my Wife took my 'B' bottle of water additions to the BottleRock concert last weekend and I need to wash it up and re-mix my additives again.
Luckily she called me and I let her know not to drink the liquid in there straight, it's supposed to be used at 10% for addition to RO water so she rinsed it out and used the bottle to keep hydrated.
-Chris
LMWDP # 272
max
#77: Post by max »
yakster wrote:Anyone using the knowledge they learned from this book to make their own custom water? I was, but my Wife took my 'B' bottle of water additions to the BottleRock concert last weekend and I need to wash it up and re-mix my additives again.
I do. I even conducted a small water cupping session with my girlfriend just to try them side by side. I did it unblinded, but she had no idea which water was in which cup. Nevertheless, the difference between tap water, Brita filtered, and my mixture was clear enough for her to find the last. I have mixed water ever since.
I later learned that the tap water contains more or less the right ratio of minerals, so I now just dillute tap water. However, I should probably look at the numbers again to make sure I'm not mistaken, especially since I'm unsure about the unit of concentration used in the official Zürich report.
In my very limited experiments, I've learned that I'm mostly bothered by carbonate hardness, and the difference seems the most apparent with lighter, acidic roasts. Here in Zürich/Switzerland water is on the harder/alkaline side and dark is the norm for roasts. On the other hand, in Stockholm/Sweden the water is soft and roasts lighter (KH: 41 ppm as [CaCO_3]). Maybe the water is what shaped the coffee cultures?
La Marzocco · Home: customized for espresso aficionados
Sponsored by La Marzocco · Home
icantlactate
#78: Post by icantlactate »
Alright guys, I'm about ready to take the plunge into making my own 'bespoke' water but wanted to run my thinking by you guys first:
I'm planning to make 200x concentrate solutions of epsom salt, gypsum salt and baking soda and combine them in various ways with distilled water to get my desired 120 ppm as CaCO3 GH : 60 ppm as CaCO3 KH. I'm planning to use sulfate rather than chloride solutions to eliminate concerns for corrosion in my stainless steel bonavita kettle. I calculated an ~115 ppm SO4 2- which seems okay based on this thread: Boiler-safe level of chlorides (and other compounds) in water.
I haven't done stoichiometry since high school. What do you guys think?
Alex
homeburrero
#79: Post by homeburrero »
Your calcs and method look fine to me. You came out with the same conversions you see here and in wikipedia for converting CaCO3 equivilents to Ca++, Mg++, and HCO3- ion.
Your method is nice because it is from scratch, and carefully shows cancelling of units in the conversions.
FWIW, note that you could have gotten to your result faster by using a commonly used unit conversion factor to get you from "as CaCO3" to molar concentrations and vice versa:
100 mg/l (or ppm) CaCO3 equivalent = 1 mmole/l of divalent ion or compound
50 mg/l (or ppm) CaCO3 equivalent = 1 mmole/l of univalent ion or compound
(mmol is millimole, 1/1000th of a mole)
These factors are good to 3 decimal places. (If you wanted silly precision you would use 100.0869 (the molar mass of CaCO3) and 50.04345 .)
One reason the unit "as CaCO3" is handy is because it's easy to divide by 100. Often you can do these in your head - divide by 100, then if it's univalent multiply by 2.
Divalent ions and compounds include Ca++, Mg++, CaCl2, MgSO4, MgSO4*(7H20), CO3--, SO4-- ....
Univalent would include HCO3-, Na+ , K+, NaHCO3, KHCO3, Cl- .....
So you can plug in conversion factors like 1 mmol NaHCO3 / 50 mg CaCO3 equivalent to quickly get your calculation into moles.
For your example:
60 mg/l CaCO3 equivalent * (1 mmol/l NaHCO3 / 50 mg/l CaCO3 equivalent) = 1.2 mmol/l NaHCO3
1.2 mmol/l NaHCO3 * ( 84 mg NaHCO3 / 1 mmol NaHCO3) = 101 mg/l NaHCO3
for the 200x concentrate,
101 mg/l * 1g/1000mg * 200 = 20.2 g/l (same as your result)
Note: Another common way to do this would be to use chemical equivalents
50 mg/l (or ppm) CaCO3 equivalent = 1 milliEquivalent/l of any compound. Then convert to mmol using 2 mEq/mmol for divalent and 1 mEq/mmol for univalent ions and compounds.
Pat
vpnogueira
#80: Post by vpnogueira »
welone wrote:Dear Home-Baristas
After a discussion with Maxwell Colonna-Dashwood today it turned out that they did indeed use test kits that measure in ppm CaCO3, meaning the same ones that are standard in the US and many other countries worldwide - and not as they state in the book and the corrigendum in mg/L of the respective ions. Also they did derive their "ideal brew zone" as well as the "acceptable brew zone" based on a one reagent titration (one for general hardness, one for the buffer/alkalinity) which measured in ppm CaCO3 (identical to mg/L CaCO3). So in practical terms this means that the lower third of their "ideal brew zone" overlaps perfectly with the higher half of the SCAA standard - or put into numbers the range of 40-85 ppm CaCO3 of total hardness at 40 CaCO3 alkalinity).
What remains still a largely unchartered territory which could be very interesting to explore is their upper part of the "ideal brew zone" which extends as far as 175 ppm CaCO3 in total hardness at alkalinity values of 40-75 ppm CaCO3 - the higher values in alkalinity being recommended/"allowed" for the values higher in total hardness.
So if you just switch out any mention of ppm (of the ions) in their book with ppm CaCO3 you are fine. Except for chapter 6 where they give instruction on how to mix water from scratch - there you have to transform the mg/L into mg/L CaCO3 - which is as they also mention in the corrigendum go as follows:
Welone,
Thank you. I am glad I read your post.
Since their Corrigendum is dated 10-10-2015, I suppose they should correct it and post a new version of the Corrigendum.
VPN
