Third wave water = thin watery extractions.
I recently got a few boxes of third wave water. I dilute them each in a 1 gallon of distilled water. Shake for a minute then wait until the cloudiness disappears. The shots are coming out really thin and taste very underextracted. They are very unpleasant and undrinkable. I switched back to Crystal Geyser and the shots are back to normal. I am using the same coffees and the same recipes. I don't understand. I thought this was supposed to be great and now I feel like I threw away my money .
- Eastsideloco
One recommendation: Add the TWW the night or day before you plan on using it. That'll give it time to fully dissolve. If you still don't like it, stick it in your travel kit and don't buy it again.
I find GC water much better overall in taste and also since it's liquid you don't have to worry so much about waiting for it to dissolve
- homeburrero
I assume this refers to Crystal Geyser, and it's always worth pointing out that CG comes from six very different sources. When selecting/recommending you need to check/specify the bottling source. EricS once posted a very handy summary table here.boldstep wrote:I find GC water much better ...
P.S. I took the liberty of moving this topic over to the Water forum where it may get better attention. It still can be seen in Tips and Techniques where originally posted via a shadow link.
Pat
GC water is Global Customized water. It's something similar to the BaristaHustle concentrates, but sold premixed in two eyedropper bottles.
- homeburrero
Thanks Mitch and Jason. - gcwater - I somehow didn't think of that. I see it's now branded as "Perfect Cup" which ends up like the old Cirqua AB formula. ( Now available here, for one example.)CwD wrote:GC water is Global Customized water.
Pat
- Eastsideloco
Global Customized's new 20-serving packaging looks to have a better price profile than the original solution. The older single-use AB package used to cost about 3x the price of buying TWW in bulk.boldstep wrote:I find GC water much better overall in taste and also since it's liquid you don't have to worry so much about waiting for it to dissolve
I don't notice much difference in the cup between TWW's Classic (non-espresso) profile and the AB formula. But the latter is definitely preferable when you need re-mineralized water immediately. While I keep both in my travel kit, I generally use TWW at home.
