Recommended water filtration for double boiler espresso machine, very soft water
Javarick
#1: Post by Javarick »
I'm going to buy a new double boiler machine and plumb it in. I live in North Vancouver, where our water varies from 2.4 to 6.7 mg/L, or the same in PPM (with slight rounding error). The water here is pretty well treated. Sand filtered, ozonated, UV-C treated, and a little Chlorine added for transport through old pipes.
Never had scale problems but that just means I don't know about them. ;-)
The biggest concern I have is sediment. Despite the good filtration, any time work is done on the water system, we get dirty water for a few hours. You can see it in the bottom of the toilet tank. After 10 years, there's a thin layer of silt on the bottom.
I don't need water softening. I suspect I should just get a plain filter that takes out sediment and chlorine.
Does that make sense?
Thanks,
Rick
homeburrero
#2: Post by homeburrero »
Javarick wrote:don't need water softening. I suspect I should just get a plain filter that takes out sediment and chlorine.
Yes. Vancouver water is amazingly soft and pure. Some more Vancouver water discussion can be seen here: How to interpret water quality document.
Pat
Baratza: skilled in the art of grinding
Sponsored by Baratza
Javarick (original poster)
#3: Post by Javarick (original poster) »
Thanks for the reference!
I'm in North Vancouver. My conclusion is to put in a filter that takes out chlorine and sediment, but not to bother to remineralize. I've been running home espresso machines in North Vancouver since 1992, and never had a scale problem.
