Rao/Perger Water for espresso
Hi all,
I'm about to dive into home espresso for the first time after years of honing pourover at home (and I'm nowhere near perfection yet!). Got a Cafelat Robot on the way, and a Niche coming this summer (and a Helor 101 w/ contemporary burrs for now), along with 2lbs of Red Bird espresso.
I use Rao/Perger water for my brewed coffee, which has a GH of 88ppm and a KH (alkalinity) of 40ppm. This makes a really flavorful and balanced brewed coffee but I'm wondering if this will also be suitable for espresso as well? I'm wondering if the alkalinity is a little too low for espresso and may result in sour shots. What type of water do you use?
Thanks all, it's a joy to join the HB forums!
Brian Hong
- homeburrero
In theory, water for making espresso will tolerate much more alkalinity than if used for brewed coffee. Here's a discussion: https://scanews.coffee/25-magazine/issu ... e-issue-9/violin_geek123 wrote:I use Rao/Perger water for my brewed coffee, which has a GH of 88ppm and a KH (alkalinity) of 40ppm. This makes a really flavorful and balanced brewed coffee but I'm wondering if this will also be suitable for espresso as well? I'm wondering if the alkalinity is a little too low for espresso and may result in sour shots.
and
Mixing three waters
It's probably best to keep it at 40 mg/L or more for machine health reasons. I don't think you need to increase it, nor will you notice a taste difference if you do. Nothing wrong with giving it a try though.
Pat
I won't be able to find you a link,
but I recently listened to a little Q/A podcast style deal with Rao. He was saying how he uses the Barista hustle method of creating coffee water, and loves it, no complaints. Added benefit for espresso, no scaling when you use Mg and bicarb.
I personally use 'Rao' recipe water with the barista hustle method
I'm certainly no authority on judging espresso quality. I definitely enjoy my pour overs and espresso drinks though.
"All people by nature desire to know" -Aristotle
- homeburrero
I'm pretty sure this is the podcast:mtbizzle wrote:I won't be able to find you a link,
https://www.scottrao.com/blog/2019/7/14 ... -scott-rao
Skip to 18:58 for the water discussion. He makes the same point about espresso tolerating more alkalinity.
Pat
That all makes sense. Third Wave Water's espresso packets have more alkalinity with slightly less general hardness. Possibly to down down the acidic taste compounds?
This may be less of an issue for Italian style espresso roasts, though that's just conjecture on my part.
Brian Hong
- homeburrero
I think that the motivation was to add a little alkalinity to address potential espresso machine corrosion. The classic formula had no bicarbonate whatsoever. They also eliminated the sodium chloride from the espresso recipe, possibly also for corrosion reasons. Then they dropped hardness a little so that it would still come out reading about 150 ppm on an inexpensive TDS meter, which was important to them. (See Third Wave Water capsules - add to water for better tasting coffee for some background from Taylor Minor of TWW.)violin_geek123 wrote:Third Wave Water's espresso packets have more alkalinity with slightly less general hardness. Possibly to down down the acidic taste compounds?
Pat
