Help choosing water filtration system for Montreal water - Page 2
- homeburrero
A conductivity TDS meter is great for checking an RO system , but is of little use when checking a conventional softener like this which replaces each magnesium or calcium ion with two sodium ions. The conductivity is not reduced, in fact it goes up slightly after softening.baldheadracing wrote:I'd try a different test kit and/or a TDS meter.
Some people with conventional cation softeners prefer using GH test kits that are designed to measure very low hardness levels, like the Hach HA-71. In this case, where the kit is measuring both tap water and filtered water in the same 100 mg/L ballpark I don't think the more sensitive kit is called for. But I suppose trying another kit may be worthwhile.
Pat
- spiffdude (original poster)
I used the test kit on RO water I got from the market. It's registering super low GH so I think the kit is ok.
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
