Easiest way to make rpavlis water? - Page 8
Yes -- it's not an exact science. Close is close enough.
Apologize, but are you saying you add 1.9g of your concentrated mixture to a falling jug for dark roast, or 1.9g of the potassium bicarbonate to the gallon? Thanks in advance.belegnole wrote:Mark, I am one of those who mixes my water by the gallon. What I do is very close to that above, but my final mix is in a gallon jug.
Here's what I've gotten from Dr Pavlis' posts.
My concentrate recipe; same ratio, smaller volume.
10 grams potassium bicarbonate
100 grams distilled water
That's it done.
Now here's where the Dr's 50-100 gram variable comes in. He stated that he would vary the strength based on the type of roast coffee. For dark 50%, for light 100%.
So worth that in mind. As I use gallons I add the following concentrate to a gallon of distilled water.
1.9 grams for a dark roast.
3.8 grams for a light roast.
Most people just use the 100% (3.8gram) recipe. Obviously you could adjust this to your taste. Others have added other minerals to do this or that. I'm not sure if there's a perfect recipe. But I like it simple, and this one is.
@Roughrider, not sure if you got an answer to your inquiry, but instead of trying to verify exactly what you were asking (as I was not sure), in the end, there are numerous ways to make the rpavlis water. Personally, I think the easiest way is:
1) For small amounts, pick up a mg accuracy scale and then add 100 mg of potassium bicarbonate into 1 L of distilled water (or whatever proportion you want).
2) For larger volumes, I make 5 gallon (19l) jugs based on RO water I get refills for, and measure out and add 1.9g of potassium bicarbonate. I have a scale that is accurate to 1/10th of a gram. To help it dissolve, I first add the potassium bicarbonate to 1/4 cup or so of boiler water, dissolve, then add to large jug. I still roll it around a bit to ensure mixing.
Grant
- homeburrero
I'm not belegnole, but it's clear to me that he adds 1.9 grams or 3.8 grams of his concentrate solution (the latter for the full strength rpavlis recipe) to a gallon of distilled water. That comes out just right for his concentrate, but would be too much by a factor of 10 if adding pure potassium bicarbonate powder.Roughrider wrote:Apologize, but see you saying you add 1.9g of your concentrated mixture to a falling jug for dark roast, or 1.9g if the potassium bicarbonate to the gallon? Thanks in advance.
Pat
Thanks Grant, that makes perfect sense!Grant wrote:@Roughrider, not sure if you got an answer to your inquiry, but instead of trying to verify exactly what you were asking (as I was not sure), in the end, there are numerous ways to make the rpavlis water. Personally, I think the easiest way is:
I think the mods should edit the initial post in RED instead of a small note I haven't seen the first time around. Creates a lot of confusion since this is the result that first pops up when googling "rpavlis water".
- homeburrero
Good point. I'll increase the font size of my moderator comment, move it right up next to the erroneous statement, and strikeout/edit the OP's text to make sure people who only read this first post get a correct recipe.
Fortunately, Google's 'featured snippet' uses text from post #4 in this thread which has the formula right:
Pat
I just bought a BDB recently, thank you so much for this thread. It got me on the right track from the start, I only have a scale that measures to one decimal place, here's how I do it. I don't know if there is too much big problem.
Concentration: 10..7g of sodium bicarbonate dissolved in 1000g of water.
Dosage: 14.8g (or ml) of concentrate for 1893ML of RO water.
I measured TDS to be 60PPM
10 grams potassium bicarbonate to 1 liter of distilled water to make a concentrate
38 grams of the concentrate to each gallon of distilled water
easy, done. takes 10 seconds for each new gallon.
