Aqua Panna vs Poland Springs not getting good crema
Since I switched to Aqua Panna on my LMLM I haven't got that good crema like I did when I used Poland springs?
- sweaner
Not sure what the question is!
Try switching back?
Try switching back?
Scott
LMWDP #248
LMWDP #248
Aren't you worried about scale? I know LM recommends but...
Crazy question, are your beans sufficiently rested?
- homeburrero
+15280grindz wrote:Aren't you worried about scale? I know LM recommends but...
Some LM online advice recommends Acqua Panna, but it is above their usual recommendations for hardness and alkalinity, including the latest LMLM manual (V 1.3) . Also, if you run it through the current LM water calculator you get this:
So if the Poland Spring (which is very soft) tastes as good or better, then by all means stick with that and avoid dealing with scale buildup in your machine.
As to the effect of the different waters on the crema, I'm at a loss as to what it might be. People who use conventionally softened hard water (with high alkalinity and low hardness) sometimes report a high crema volume that dissipates quickly. There's an old thread related to that: Water hardness and crema. I would have guessed that Acqua Panna with the high hardness and alkalinity might have given you if anything a little more crema than the very soft water.
Pat
