CONCLUSION: The single dosing system is ultra convenient. The grind quality for brewing is good, but not as good as high end specialty brew grinders. It is very easy and repeatable to change grind settings. Therefore, there is no other "all in one" grinder that even comes remotely close. However it is a good deal more expensive than most budget "all in one" grinders.
For someone looking for an uncompromising, single dosing espresso grinder on a budget, this is it.
FEATURES:
- No retained grind - Current grinders often trap large amounts of coffee in their grind chambers. As we know, ground coffee starts to go stale in a matter of seconds. So the next time you grind, your coffee is being tainted by the old trapped stale grind.
- 63mm conical burrs - delivers a single dose of high quality grind. You can produce the right quantity of fresh grind you need for immediate use by weighing out your beans, knowing you'll get the same weight in grind.
- Quiet - an optimal burr speed, giving you the best grind quality at a quiet 72dB
Rating: ★★★★★ (5 out of 5)
