VST/ Strada Basket for Silvia - Page 3
It's always good to learn from other peoples' experiences. I plan to purchase a bottomless portafilter very soon, which comes with a triple basket. As I have never used a triple basket, it will be interesting to see how it works for me.
- JohnB.
No, it depends on the size of the dose you use. I like the 14g for doses up to & including 18g. The 21g double works well between that range & triple mega doses which for me start at 21g & go up.Coffeematt13 wrote:So John, are you saying that you would recommend the 21g ridgeless over the 14g ridgeless?
LMWDP 267
I see. I wasn't sure if the 14g hq baskets would be able to hold 18g of coffee.
- LeBreadman
I have a silvia v3 and a 18g ridgeless VST basket and I must say that they are frustrating to use because a small variation in the variables have an impact on the shot (so especially on the silvia). I went back to the triple LM basket that came with my naked PF with the same dosing and my shots are better!
- JohnB.
No idea why they call it a 14g basket. The Synesso 14g double is the same story as it easily holds 18g.Coffeematt13 wrote:I see. I wasn't sure if the 14g hq baskets would be able to hold 18g of coffee.
LMWDP 267
- Tag Team Jesus
Because the Versalab grinder has it's donut distribution in the basket, I find it works best to overfill the grounds so they can easily be redistributed into the middle where the donut hole is. That being said, I could really use a better basket that will get overfilled for my 18 gram shots. 18 grams often looks a little skimpy in the double basket. So, I think I'll order that 14 gram HQ basket.
A lot of HQ talk in this VST thread.
- LaDan
In which 18g basket, the VST or... ? I have the same issue with the 18g basket. I developed some kind of Stockflech with my finger going down into the basket to distribute and level at about 3mm below the rim.Tag Team Jesus wrote:Because the Versalab grinder has it's donut distribution in the basket, I find it works best to overfill the grounds so they can easily be redistributed into the middle where the donut hole is. That being said, I could really use a better basket that will get overfilled for my 18 gram shots. 18 grams often looks a little skimpy in the double basket. So, I think I'll order that 14 gram HQ basket.
If I fill up the basket to level to the rim then it would not tamp low enough.
- Tag Team Jesus
18 grams yields skimpiness in my HQ double basket. Just ordered a HQ 14 gram ridgeless. NeatO. If you can level 3mm below the rim, I am impressed. Post a video! I never understood how to distribute a coffee if the dose couldn't level with the rim.LaDan wrote:In which 18g basket, the VST or... ?
I have VSTs, but have put them away until I get very comfortable with my new setup on HQ. No rhyme or reason....I just picked these baskets for now.
- LaDan
Hi Jon, I can't take a video, so instead I took pictures and wrote a thousands words. Started a thread to answer your question, it's just too long and didn't want to hijack this thread.
Here it is: Underdosed Stockfleth - When your dose is below the basket rim
- erics
- Supporter ★
Then take the spring out of the portafilter, buy several baskets (they are obviously inexpensive), and "knock" the baskets. Baskets are a disposable item - but, for sure, long term.
The modus operandi certainly depends on YOUR particular routine and the duty cycle you impose on Miss Silvia but this makes multiple drink prep all the more easier, not to mention weighing and distribution.
