VST Basket Longevity
Someone mentioned something about how long these last in another thread recently, and I can't seem to find any direct information about how often I should plan to replace my VST baskets. Are they rated for a certain number of uses?
I've been using mine for over 4 years now (three plus times a day), even throw them in the dishwasher every night...still going strong!
- baldheadracing
The generic (not VST) basket ratings I've seen (40k shots) work out to about 25 years of heavy home use ... but if you must, buy two, make sure that they match flow rates, keep one unused in a drawer, and compare every few years.
Also: What Causes a Broken Basket?
- cannonfodder
Baskets do ware and the holes will slowly enlarge from erosion over time but it takes a lot of shots. In a home setting, the baskets will probably outlast you.
- BaristaBoy E61
I would say that if you regularly clean a VST basket and you see no signs of metal fatigue that you're good to go.
As previously stated, they'll probably out last you. Ours is over 6-yrs old and going strong at 2-shots per day minimum.
I have three springless 15-gram VST baskets that I cycle through during the day. Most days I pull three 15-gram espressos; if I make a different number, I just continue the cycle the next day. This procedure removes any anxiety about wearing them out before my time.
