Unexplained extraction time changes
Hi There,
Fairly new to espresso at home (6 months) and to make things repeatable, I've been using the same beans and logging...
The grind and everything is the same (same basket etc), even ambient temps and humidity logged have been fairly constant (17-20º, 50%-56% humidity). The longer times recorded this morning were at 17-18º and 51%-52% humidity for example. I pulled three shots just to be sure.
Questions:
Is it possible that changes in roasting could cause this or maybe the number of days since roasting?
Is there anything else I should look for?
A 20sec change in extraction time is a bit weird right? Any pointers in the right direction would be much appreciated.
Cheers
Ben
- Grind
- Dose in
- Extraction out
- Brew temp range
- Amount of beans in the hopper
- Ambient temperature and humidity
Questions:
Cheers
Ben
Yes, all else equal, extraction times can change with age. You can see it happen in this experiment, for example: http://www.youtube.com/watch?v=6TMkDe1XtIMBenS wrote: Is it possible that changes in roasting could cause this or maybe the number of days since roasting?
Since coffee beans are an agricultural product whose availability can be affected by all sorts of factors, I wonder if your roaster could have also changed the beans they are using or some component of the blend (if it is a blend). That could also impact your shot times.
If you are able to rule out a technique issue because you're logging/repeating all of your process and you have seen very consistent results before this AND if you ultimately think is not a about the coffee itself, then you could check if anything is affecting the brewing pressure in your machine.BenS wrote: Is there anything else I should look for?
Thanks guys, will pay more attention to bean age and log it! Cheers
If everything is the same then you should check your machine. In mine after a few years suddenly I couldn't get any steam from it. It turned out is was scale. After discaling everything was fine
Weigh your coffee again after it's gone through the grinder to ensure the dose is still the same, accounting for any addition of water through RDT.
I need to do the same. Not necessarily every day, but as the beans age the grind needs to get a little finer.SandraF wrote:Each day I adjust my grind slightly finer to compensate for the aging of the bean.
To the main question, a 20 second difference is a lot. I get 5 second swings sometimes but not 20 second swings.
- Supporter ★
Changes in roast definitely, even if from the same roaster and same name of roast. Did you just switch bags when this happened?
Time from roast is very important, but usually as the beans age it runs faster, not slower.
