To Control Flow or Not?
So, I have ordered a new ECM Classika that I hope arrives sometime next week, I am excited for the new equipment. I have been using a lever for a while now which I enjoy, but my wife does not like using it at all. She works form home and would enjoy a midday espresso if it weren't for the lever machine not cooperating for her, hence the pro-sumer machine.
I have not had a machine with flow control before, so I am looking for opinions on whether this would be a worthwhile modification/upgrade to the stock machine. After a quick internet search I saw one ECM flow control kit that was $399.00, seem steep to me for what is included. So, any recommendations on ow to purchase one would be welcome if the consensus is that it's a worthwhile purchase.
Thanks!
Thanks!
Cheers,
Patrick
Patrick
Get it! The Coffee Sensor version is cheaper, at least here in Canada, and it's just as good, perhaps better. If nothing else, you have a variable jet (gicleur) that you can either play with, or set and forget (assuming you keep the stock e61 spring). I "dial in" my FCD when I change coffees. On the first shot, I turn the FC slowly open until the flow reaches the maximum it can, and leave it there. When I pull a shot thereafter, I watch the gauge go up to roughly match the pump pressure, then watch it slowly drop as the coffee solids and oils are leached out of the puck. I can see the "blond point" when the needle ceases to drop. Also, if I have a puck problem, such as channeling, I can see that immediately as a quicker than normal drop. Sometimes, I can salvage the shot by turning the control down. I used to mess with the control a lot more, but as time has passed, this is how I use it at least 90% of the time.
If you plan on adding flow control to your own brand new machine, I've been told it will void the warranty.
- BaristaBoy E61
Where did you purchase this from Maurice & approx. price?Nunas wrote:Get it! The Coffee Sensor version is cheaper, at least here in Canada
TNX
SandraF wrote:If you plan on adding flow control to your own brand new machine, I've been told it will void the warranty.
I wondered about this, and in speaking with shop I've purchased the machine from they told me it would not void warranty. I had called after my purchase to see if they stocked the ECM/Profitec flow control kit in hopes of adding it to my order, but they don't stock it.
Now if I were to go with another brand of kit it likely will be a different story I think, so I have that to consider.
Cheers,
Patrick
Patrick
Nunas wrote:Get it! The Coffee Sensor version is cheaper, at least here in Canada, and it's just as good, perhaps better. If nothing else, you have a variable jet (gicleur) that you can either play with, or set and forget (assuming you keep the stock e61 spring). I "dial in" my FCD when I change coffees. On the first shot, I turn the FC slowly open until the flow reaches the maximum it can, and leave it there. When I pull a shot thereafter, I watch the gauge go up to roughly match the pump pressure, then watch it slowly drop as the coffee solids and oils are leached out of the puck. I can see the "blond point" when the needle ceases to drop. Also, if I have a puck problem, such as channeling, I can see that immediately as a quicker than normal drop. Sometimes, I can salvage the shot by turning the control down. I used to mess with the control a lot more, but as time has passed, this is how I use it at least 90% of the time.
I have started reading your thread about the flow control and I am looking forward to reading the rest as I've already learned several things.
Cheers,
Patrick
Patrick
- baldheadracing
Here's Coffee Addicts in Calgary for eventual comparison: - $260CAD shippedBaristaBoy E61 wrote:Where did you purchase this from Maurice & approx. price?
TNX
https://coffeeaddicts.ca/products/coffe ... 2525253822
@1rider - I bought my Synchronika from Clive in Portland. Someone there said this to me. I didn't question his authority to say that, as I'm not really interested in adding it.
I think it depends a lot on what kind of roasts you like. I go for the more traditional dark roast and for me the flow control didn't add much. I took it off and sold it to a fellow HBer. If you're trying to keep it simple for your wife I'd try the machine without it first.
