Such a simple adjustment to my routine - Page 2
My money says it's on the countertopF1 wrote:Where are all those .1g going to?
- JR_Germantown
So your grinder is retaining coffee at a rate of .1g per dose? What eventually happens, does it fill up?Deebo wrote:That's interesting, I have the 270 and single dose. I put 20g in and get 19.9 out, every single time.
Edit: Oh, snap. Didn't see the previous two posts that were better than mine.
Jack
Definitely! - usually weigh out whole beans about 0.7 to 1.0 grams more than what my goal weight is (16.0 grams in my case), rdt, grind into a cup, then place the portafilter and funnel on the scale, zero it, dump in coffee and spoon off the extra to get within 0.2g, wdt, remove funnel, tamp. There are too many other variables not to weigh what actually goes in the basket.
LMWDP #600
Yea, good one...F1 wrote:Where are all those .1g going to? Another dimension? Maybe there is another you in that other dimension who always puts 20g in and gets 20.1g out.
So by your logic I will eventually have 100,000,000 grams retained? Makes sense... no, sorry.
Think it, but don't overthink it...
Q1: YesJR_Germantown wrote:So your grinder is retaining coffee at a rate of .1g per dose? What eventually happens, does it fill up?
Jack
Q2: No
You owe someone moneyidrinkjetfuel wrote:My money says it's on the countertop
I'm not sure. Mine required a shim pretty quickly after unboxing to keep the grind setting in place, otherwise it would drift. That wouldn't explain retention, but my point is that these grinders don't always come out of the factory operating at 100%. My guess, compared to mine, is that it's defective. One of the main reasons I bought this grinder was because of the supposed near-zero retention, which has proven to be true in my case. If it were me, I would contact Baratza, I've been quite happy with mine status-post shim.liquidmetal wrote: Really? I wonder why mine is inconsistent...
Jack
I'm sure that since there's so much wit bouncing between the three of you that you can combine your smart brains and perhaps reach a different conclusion... I can give you a hint if you need it.
