Shot starts at 6 secs, good taste but low volume
- DJL
Hey there,
Hoping to get some pointers. Fresh beans, dark roast, My double shots (18 grams) in 58mm basket start around 6-7 seconds, but by 25-30 seconds I'm getting less than 1.5 ounces. Good taste and nice crema, but not getting the yield expected. Any suggestions on why this is happening?
- Supporter ★
What is the weight of your output? Volume is a pretty meaningless variable, when discussing extraction.
What makes you think that is not a good yield?DJL wrote:Hey there,
Hoping to get some pointers. Fresh beanst, dark roast, My double shots (18 grams) in 58mm basket start around 6-7 seconds, but by 25-30 seconds I'm getting less than 1.5 ounces. Good taste and nice crema, but not getting the yield expected. Any suggestions on why this is happening?
Seems to me it is ideal, especially if it tastes good and the crema is good.
I would recommend using a scale vs volume. Much more accurate and easier to diagnose.
Carm
New York, NY
New York, NY
- DJL (original poster)
My yield from 18 grams at 30 seconds is about 26 grams, shouldn't this be closer to 36 grams? 1:2mivanitsky wrote:What is the weight of your output? Volume is a pretty meaningless variable, when discussing extraction.
I thought a double is closer to 36 grams of espresso, especially (for 1:2) from 18 grams of coffee.SJM wrote:What makes you think that is not a good yield?
You are confusing me, but I'd say that good taste and good crema outrank theory any day.
Long before I started weighing output I looked at the output in a shot glass, and my favorite shots (from my Gaggia) were always marked at about 1.5 ounces. Thick and juicy and very slow to ooze out of the portafilter.
Haha! Sorry a couple of typos in my last posts (fixed). For a double shot using 18 - 20 grams should I not be getting a yield between 30-36 grams of espresso within 25-30 seconds?
Not necessarily, but if that is your objective, you could probably just coarsen your grind a bit.
- Supporter ★
You are pulling a shot that is more restricted than a double, but if taste and mouthfeel is good, who cares? Go by what you like, not by some specific number that you shoot for. Grind more coarsely if you want to get more volume in the same time.
