Sediment from hot water spout - ECM.
I use hot water to heat up my cappuccino cups every morning. I've noticed that there is sediment in the bottom of the cup. Looks like fine coffee grounds. I clean the machine every day, back flush and purge some hot water and it's still there.
Any ideas?
Any ideas?
- BaristaBoy E61
Are you using non-scaling water?
Yes, that's it.
I'm using the Homeland water filter.
Thanks.
How can I avid the sediment? Run more water through the system?
Thanks.
