What paper filter did you use? Mine speeds it up quite a lot (kafatek robot filters), so it sounds like you have a very dense filter!atao wrote:Quick update.
I adjusted LM pump pressure from 9.5 blind to about 7 blind.
Resulting extraction was a bit faster but with same total weight output, extraction % was largely similar.
I tightened the grind a full tick on the niche and pulled another shot and oddly enough the extraction % fell from 18.3 to about 17.8.
Paper filter on bottom of basket with the baseline grind setting slowed the shot way down and yielded a very slightly higher extraction%, 18.4, probably within noise.
Then I ran out of coffee
Puzzling extraction difference - Olympia Cremina vs. La Marzocco Linea Mini - Page 3
The LMLM _has_ pre-infusion. When you first move the paddle from right to left there is a delay before the pump activates. In that interval that is appx 1 sec the machine introduces line level pressure water to the puck.atao wrote:Is there a sort of manual preinfusuion I should try, like pouring a bit of hot water on the bed before locking the portafilter?
2 things:
1-The app which may require a hardware/control board update if the machine is an early version, allows for the user to modify pre-infusion.
2-without the app or board change, the user can move the lever from off and on then back off again before the pump activates. Let puck swell a sec, repeat if desired or not, depending on results.
If you don't like the LMLM, I can find a home for it. Or the Cremina, for that matter.
Yes, i'm well aware of this. I've said it a couple times in this thread that i don't have the hardware update.
Is it true that you can manually preinfuse by sliding the lever forward and backward? Doesn't that trigger the flush valve?
Ok, some interesting developments.
I had to go to a new coffee (Counter Culture Hologram).
New baseline measurements:
LM: 15.5g dose -> 35.4 out -> 17.8%
Cremina: 14.5 dose -> 37.2 out -> 20.1%
And this did make me realize that my ratios were quite different, with LM about 2.3 and Crem at 2.6.
So i pulled LM in similar ratio:
LM: 16.6 -> 41.7 ratio = 2.5 -> 18.1%
This only bumped up the extraction % a little. I realize i changed 2 things, but anyways, i hadn't seen much extraction drift with larger doses, so.
Here's the interesting experiment:
LM: 16.6 -> 41.6 but with pre-wetting (i pour about 1tsp cold water on puck and let it sit for 10 sec) -> 19.5%!
So, the pre-wetting took the extraction % up about 1.4%. That's rather significant.
I did try one shot with pre-wetting via the LM lever, where i prepare puck normally, and then instead of dumping cold water on the puck, i move the lever to the middle for a second, and then back to the OFF position and wait 10 seconds, then pull shot normally. This resulted in 19.1%, not quite as high as the cold water but still 1% higher.
So this leads me to think that i should be considering the programmable pre-infusion on the LMLM.
I haven't read those threads where people evaluate the pre-infusion. Is there any data there that either confirms or denies these observations above?
On a tangent, i'm all out of VST syringe filters. Anyone have a recommendation for an alternate source for them? Every time i buy them from VST i feel like i'm losing my shirt.
atao wrote:On a tangent, i'm all out of VST syringe filters. Anyone have a recommendation for an alternate source for them? Every time i buy them from VST i feel like i'm losing my shirt.
I've used these and they work well enough. They are a little less expensive than the VST ones. There are cheaper syringe filters but I've read mixed reviews.
Some people use mini centrifuges. Careful tests (e.g. https://awasteof.coffee/2019/02/12/cent ... -espresso/) have been run that demonstrate that they work about as well as syringe filters. You can find used centrifuges on ebay. Even a new one can be had for under $200. They are a little more effort than a filter but still pretty easy to use. And having zero recurring costs has to be mighty tempting if you're using your refractometer frequently.
I pivoted to Apollo from Counter Culture.
It has been a complete surprise to me that larger doses are yielding greater extraction percentages.
With a yield of about 2:1, my 18gr shots in a 20g VST are extracting only ~18-19% while my 19gr shots are yielding ~20% extraction.
This is a total surprise to me honestly. It has never been a tool in my arsenal that to increase extraction, you should increase the dose! I believe that I read threads on this very forum (was it from another_jim) where the guidance was that if you're having trouble extracting enough, then focus on lower doses and finer grinds.
This experiment was done with only a few shots but assuming it's repeatable, it leaves me wondering if this is simply a well understood behavior of espresso brewing (that I've clearly been ignorant to) in general, or is this more of a LMLM dynamic.
By the way, thank you for the syringe filter tip @jpender, I got them and they're working out well.
