Puck paper purveyors? - Page 6
Okay, some high flow resistance paper is in my future...
It would be interesting to try this in a 'layer cake' three-paper stack: Filter paper shot forensics
My initial guess is that it will go badly, since the 2.5um paper will have a significantly higher flow resistance than the coffee grounds. On the other hand, the AeroPress paper I've been using mid-puck is largely transparent to the flow resistance - but seems very effective at stopping top-to-bottom channels from forming.
I picked up one of these since the ability to change sizes was appealing, plus they are more compact, easier to store, slightly less expensive, and have replaceable blades.ohwhen wrote:I think it would be slightly more cumbersome than a punch cutter but you can also look for "circle cutters" that are adjustable.
Would not recommend:
1. Fiddly
2. Leaves a hole in the middle of the paper (and to avoid the hole makes the cut more challenging)
3. Slow
4. Not easy to do more than two filters at once
I ordered a pack of the Aieve papers on Amazon. They seem to be the generic ones that are sold under a few names. I've compare them with the Aeropress filters once I get them on Monday.
