Leave Portafilter In Group?
Beginner and pro baristas share tips and tricks.
jyl
Postby jyl » Apr 13, 2019, 1:50 am
Do you leave the portafilter in the group when not in use?
Someone told me that having the pf repeatedly cool and heat can cause them to warp.
This is a commercial machine that is "on" 18 hrs/day.
I'd been leaving the pfs on top of the machine for no particular reason. Looked tidier maybe.
John, Portland OR
Vintage bicycles, Porsche/VW, cooking, old houses.
slipchuck
Postby slipchuck » Apr 13, 2019, 11:58 am
No way a portafilter should warp.
You want to keep it in in order to have it heated to pull a shot
Randy
Nunas
Postby Nunas » Apr 13, 2019, 12:52 pm
Nonsense. I've always left my portafilter in my machines. I have had six espresso machines so far, and none of the portafilters have ever warped. Like Randy, I leave them in the machine so they'll be up to temperature when I want to pull a shot.
Monsoon
Postby Monsoon » Apr 13, 2019, 12:55 pm
X3
daveR1
Postby daveR1 » Apr 13, 2019, 1:39 pm
Keep the PF in not only to keep it warm but it covers the grouphead to keep it at a proper temp. Leaving it exposed without the PF makes it harder to maintain desired temp consistently
spressomon
Postby spressomon » Apr 13, 2019, 1:47 pm
Tip: Don't take any more advice from the certain "someone" all things coffee/coffee hardware related :D
No Espresso = Depresso
cannonfodder
Postby cannonfodder » Apr 15, 2019, 3:46 pm
The only issue you will have is if you tighten your portafilter into the group as if you were pulling a shot. That can cause premature wear on the group gasket from the compression. Beyond that, the large thermal mass of the portafilter will help regulate the group head temperature. Locking in a cold/room temperature portafilter will also cause your group head temperature, even with a large E61 or saturated group, to drop like a rock. I have seen them go down almost 10 degrees simply putting in a cold portafilter.
jyl
Postby jyl » Apr 16, 2019, 7:33 am
Okay, loosely mount the PF in the group. Thanks!
John, Portland OR
daveR1
Postby daveR1 » Apr 16, 2019, 7:45 pm
cannonfodder wrote:The only issue you will have is if you tighten your portafilter into the group as if you were pulling a shot. That can cause premature wear on the group gasket from the compression. Beyond that, the large thermal mass of the portafilter will help regulate the group head temperature. Locking in a cold/room temperature portafilter will also cause your group head temperature, even with a large E61 or saturated group, to drop like a rock. I have seen them go down almost 10 degrees simply putting in a cold portafilter.
Exactly!
