Thought I'd share what I'm using for a knockbox. It's a metal compost bucket from Williams Sonoma (small, countertop sized). I use it like a knockbox, while my wife puts banana peels and other vegetable remnants inside. After a couple of days we take it out and dump it on the compost pile. We have a nice compost pile already for next spring's gardening.
It has a filter in the lid, so there's no smell.
http://www.williams-sonoma.com/products/fn415/index.cfm
More expensive than most knockboxes, but not by a lot, and it does function well for compost. I had a gift certificate, though - probably would not have bought it (or any other knockbox for that matter) otherwise.
Knockbox alternative
- mckolit
How do you knock the puck out? Do you just bang it up against the rim of the pail? I'd be wary of doing that to a $50 "knockbox" though.
- Bex (original poster)
Yep. It's stainless and I haven't had an issue with it getting knicked, but the rim of the cover would hide any knicks anyway.
- r-gordon-7
But what about suffering kincks to the rim of the portafilter or the basket if you're knocking against a stainless steel rim of a pail and not against the rubber bar which most dedicated knockboxes have for this purpose?
r-gordon-7
r-gordon-7
r-gordon-7
LMWDP #188
LMWDP #188
In Italy we used an oak frame over a trash can. Basically it was a frame that fit over the edges of the rectangular opening with a 2" or so oak dowel across the center (like a bridge) that you would knock the pf on. The oak didn't ding the pf but it was hard enough to take the abuse.
Ben King.
I can take pictures if you'd like. Neither the handles of my PFs (VBM) nor the rim of this compost pail have sustained any damage over a month of use. Note that due to the design of the VBM PF, I am not hitting metal on metal; I just hit the handle on the rim and the puck pops out.r-gordon-7 wrote:But what about suffering kincks to the rim of the portafilter or the basket if you're knocking against a stainless steel rim of a pail and not against the rubber bar which most dedicated knockboxes have for this purpose?
r-gordon-7
- r-gordon-7
Bex, glad to hear your pf handle and rim fare well... Frankly, I never even thought of knocking against the handle, as my experience is only with pf's having ridgeless baskets, necessitating the knock be solidly against the pf/basket rim - "or else"...
r-gordon
r-gordon
r-gordon-7
LMWDP #188
LMWDP #188
I don't see why that's a better "solution" than taking the grounds from your knockbox and adding it to your compost bin outside the house, along with all your household scraps, etc., etc. I suppose it would save counter space, if your countertop compost receptacle and knockbox would be in sufficient proximity, you'd only have one item on the counter instead of two, but . . .
We don't have a compost heap/pile/generator. For us, I just take the knockbox and add it to the green plastic, City of Berkeley-supplied compost bin, which -- in turn -- gets collected weekly along with the newspapers, bottles, cans, plastics, etc.
Cheers,
Jason
Cheers,
Jason
Here's how I modified mine to knock the puck out:mckolit wrote:How do you knock the puck out? Do you just bang it up against the rim of the pail? I'd be wary of doing that to a $50 "knockbox" though.
This saves me the step of emptying and cleaning my small knockbox after each use. I just knock it in this, put the lid on when done and put it back under the sink. I empty it in the flowerbed once a week or so.
-Don
