Izzo Alex Duetto 3 dripping water from underneath
Ok, so I just got done saying how I have not had an issue and have been enjoying my machine for the last year in another thread. Not 8 hours later I noticed that water drips from the bottom after it cools down
Saying drips sounds minimal, after turning off the machine at the end of the day before bed and returning in the morning I find a pool of water flowing in on to the floor. It was on the majority of the day. Other then this it works fine. The pressure is where it should. It does not drip while the machine is hot.
I have opened it up and cannot pinpoint where it's coming from.
Does anyone have any ideas on what might be going on?
"As you know, an explorer's temperament requires two basic qualities: optimism in attempt, criticism in work."-Freud
Usually this is one of the heating element Teflon gaskets leaking, most likely the brew boiler one as the bottom shape of the brew boiler makes it especially hard to fit correctly.
I replace them for friends using a central heating pump Gasket, which is thin and flat (the EDPM type, not the red fibre one) and a thin smear of Dow 111. On the brew boiler, fixes like these have held up for more than 5 years so far, on the steam boiler, I'm not sure, but it should be OK. The heating element when using these should not be tightened too hard at all, otherwise you risk damaging these types of gasket.
Not that I have any answers, but it may help others diagnose if you mention whether it's plumbed in and/or drained...
The "leaks" I've had underneath my Duetto were a result of a clogged drain tube but that doesn't seem to be your issue given it occurs specifically after the machine has cooled down
It is not plumbed in or drained.
