catalinH wrote:The coffee used was Ethiopia Uraga from da Matteo roasted for filter.
My Ek is OCD alligned,also I've replaced the carrier with a turkish one from Frank.
Although your conicals may produce less boulders than my Robur,you will still not hit a 25%EY using a conical grinder because of the widw particle distribution.Another obstacle in achieving high extractions is the obsession of producing ratios
so my questions remains: What is there to love about 1:2 ratio?
You need to use a syringe filter and/or centrifuge before you use your refractometer for espresso shots. There is no way that reading is accurate.
...split from Top 5 Grinders for Light Roast Espresso Application by moderator...
