How to tamper asymmetrical, one-legged portafilters for single shots?
Beginner and pro baristas share tips and tricks.
halloleo
Postby halloleo » Mar 10, 2017, 7:28 am
I just acquired a brand new and shiny espresso machine. It comes with a "one-legged" portafilter for single shots. Good for my solitary coffee after dinner! :-)
However, how do I tamper a portafilter which does not stay properly on the benchtop? Mid-air just holding it in one hand and tampering with the other? Or do the tampering with the basket taken out of the portafilter? At the moment I use the edge of the benchtop to let the spout "dangle down" and keep the middle bit of the portafilter on the benchtop, but I have to be careful because this way it is easy to slide off the bench...
What do others do?
ebola5114
Postby ebola5114 » Mar 10, 2017, 8:29 am
Hey !
Look at the device named "tamper stand" or "tamping stand", is what you need to...
D.
erik82
Postby erik82 » Mar 10, 2017, 8:48 am
Take the clip out and take the filter basket out. Dose and distribute in the filter basket and then put it back in the portafilter.
jfrescki
Postby jfrescki » Mar 10, 2017, 10:05 am
Option 3, put the underside of the portafilter on the edge of the counter (you don't need fancy tamping mat).
Write to your Congressman. Even if he can’t read, write to him.
- Will Rogers
bshuff
Postby bshuff » Mar 10, 2017, 1:27 pm
Not the most elegant solution, but I use a PVC plumbing reducing hub adapter. I keep looking for a real tamping stand but have not found one I liked. The pvc pipe is light enough to use on my scale
halloleo
Postby halloleo » Mar 11, 2017, 4:24 am
Thanks for all the answers - I will look into a tamper stand...
BaristaBoy E61
Postby BaristaBoy E61 » Mar 11, 2017, 3:09 pm
If what you're after is a stand so that you can really manipulate the coffee in the portafilter, then this would be my first choice.
https://www.tidaka.net/de/tampercube/tampercube-adapterring.html
LWW used to make a nice one but it's out of production. I wish they would bring it back!
http://lynweber.com/accessories/pf-cradles
cuppajoe
Postby cuppajoe » Mar 11, 2017, 3:36 pm
I've been using one of Mr Pratt's stands for a couple of years. simple, works well, and easy to clean.
https://www.cafelatstore.com/products/c ... ping-stand
David - LMWDP 448
