How many espressos to dial in a new bag of coffee?
ZebcoKid
#1: Post by ZebcoKid »
Hello all,
This is just a check on "normal".
I have a roast that I use regularly. By accident, I picked up a roast that was a little less dark.
It took me about 4 pulls to get the flow right as I had to keep lessening the grind.
Is this process typical when working with a different roast? That is...unless you're super experienced (which I'm not) or fortunate, you're going to be tossing a few cups.
Thank you.
ZK
Pressino
#2: Post by Pressino »
This is a very good general-advice video from Marc at WLL on dialing in grind size to extraction rate/time:
mckolit
#3: Post by mckolit »
Yep. Usually what I do. I adjust the grind to get the shot time and then start adjusting temp after.
ZebcoKid (original poster)
#4: Post by ZebcoKid (original poster) »
Pressino,
Just what I needed to hear, see, and know.
Thank you!
ZK
