Help Adjusting Flavor - Page 2
- slipchuck
I bought an Espro a couple of years ago and I really like it. It helps take one thing out of the equation.OK31 wrote:Thanks everyone. Yes I really need to get a more precise scale to help with weighing in and out. It's in my radar. As for milk drinks unfortunately I was on a roll and there's only so many drinks I can have at 8pm lol.
I have been doing the tap and tamp which may well be responsible for the shot starting strong and then having pressure drop though it's still well in the range where I want it. I'm thinking I probably want to go one more notch lower on size and lower the dose to maybe 15ish to see if I can get that good flavor without choking. This morning I got about 17g in PF and at 35sec got 32g out in cup which is probably great but think I could have gotten a little more flavor in a little less time. I am finally understanding that there is not wrong way its just what you like. So in reality all these coffee shops give you their interpretation. If you want your own then this is the way to do it and at the end of the day considering I won't be doing many shots straight it will not be as impactful though noticeable in milk.
Is a calibrated tamper worth it? And those who have had the grinder pro what did you find as a good balance on the grind size? Considering you can make it flow in 30 seconds using dose size and tamp in so many combos it's like probability all over again. Doing all shots in a row I found helpful to taste each otherwise doing it across days just spreads the torture while not wasting which I need to stop.
Next problem stretching milk and pouring. Science is one thing art well that's a whole other business.
Randy
So you basically overdose initially then tamp and razor out the rest to keep as close head room to the "recommended" as possible by breville at least. That's something I should try, the grind may increase but that may offset the flow. I'm still not sure I understand how/why lowering the dose which effectively leaves a lot of headroom is a good thing? Sure the flow will adjust as will the out weight but then you're effectively brewing under pressure rather than pulling no?HH wrote:The grind setting varies for me based on the beans I'm using, how old they are etc. I'm currently on 11, grinding for 17.2 seconds to give me 21g in the basket, but on my last bag of beans which was a different bean and roast, I was up at a setting of 15. Just change one thing at a time and you'll have it dialled in in a couple of shots. I keep tamping pressure and dose absolutely consistent which makes it a lot easier when trying new beans.
With regards to calibrated tampers and tamping variables, just tamp to full compression (until you can't physically tamp more), which cuts out the pressure variable completely.
Yup. At least to work out what your recommended dose is for the included Breville basket. You only really need to do it once, most of my experience and reading shows in the stock Breville basket for the 920 it's geared for a 21g dose. Would be worth checking to make sure yours is the same (I'm not sure whether the baskets stay the same between machines, the 920 uses a 58mm basket). I found dosing the Breville to 18g (which I saw a lot on the forum as many members use VST baskets) made the shots far less flavourful and gush through a lot more quickly, so it was hard to find a grind that corrected it. Since dosing at 21g I haven't had a problem with the SGP.OK31 wrote:So you basically overdose initially then tamp and razor out the rest to keep as close head room to the "recommended" as possible by breville
- slipchuck
I believe the infuser has the same basket as mine. 18 grams is about maximum. The issue with using the razor is that different coffees will sit at different heights in the basket and so will how fine you grind.
Randy
Randy
The infuser is a 53mm basket and based on recommendations says 15g to 18g. The problem is as noted below that different grind size will impact the size in basket and the fluffier stuff at 16g may be same height as 18g of another so is it just a matter of knowing your beans and really just testing the shot?HH wrote:Yup. At least to work out what your recommended dose is for the included Breville basket. You only really need to do it once, most of my experience and reading shows in the stock Breville basket for the 920 it's geared for a 21g dose. Would be worth checking to make sure yours is the same (I'm not sure whether the baskets stay the same between machines, the 920 uses a 58mm basket). I found dosing the Breville to 18g (which I saw a lot on the forum as many members use VST baskets) made the shots far less flavourful and gush through a lot more quickly, so it was hard to find a grind that corrected it. Since dosing at 21g I haven't had a problem with the SGP.
OK, won't claim to be an expert, but I haven't seen any comments about the big red flag (as I see it). You should be aiming for a 2-to-1 ratio, which means that shots 1-3 are way off. When I'm dialing in, the first thing I aim for is 2-to-1 in 35 seconds (assuming 10 sec. preinfusion). Then modify from that point. It doesn't seem like any of these shots are there, but the last one was closest.OK31 wrote:Pull time recording started immediately at double shot button press, first drips started at ~9-11 sec
1st shot 15 sec grind, 12 size 18g in PF, 45g out in 32 sec - sourish kind of weak not something I'd enjoy
2nd shot 14 sec grind, 11 size 16g in PF, 44g out in 31 sec - sourish similar to above but definitely less "watery"
3rd shot 14.8 sec grind, 9 size 18g in PF, 40g out in 35 sec - better not AS sour but still a hind of that eh... at this point all 3 would probably be fine with milk but that's not what this is about RIGHT?!?!
4th shot 15.8 sec grind, 8 size 17g in PF (remember it may be closer to 18 or 16) 36g out in 40 sec - this tasted the best out of all, sour almost if not completely gone started to get on the cusp of bitter but not, taste lingers but can maybe be better?
Secondly, get the 0.1 g scale. The difference between shots that are off by 1/10 a gram is noticeable. You won't be able to replicate accurately with the equipment you have without a better scale. You will never regret spending that $20.
Kevin
Thanks Kevin yes consistency is kind of a challenge at this point so that scale is definitely on the list to get.
You now have two primary limiting factors: grinder and scale. If you are sticking with the SmartGrinder, the scale is necessary. I had the SmartGrinder for less than a year before upgrading to Vario-W, and was constantly frustrated. I always felt like I was this close to getting the right grind setting, but rarely hit the sweet spot. Life is better now.
Good luck!
Kevin
Good luck!
Kevin
Thanks, I'm not sure the vario w is in my near future so will have to make do but yes scale is on the docket. Thanks again.
Honestly I haven't noticed much difference between beans when using the razor. I have only tried it on 8 different varieties with the razor but the dose on all of them was within 0.1g of each other after using the tool. You only use the razor tool after tamping, so fluffiness of grind and distribution technique doesn't come into it.OK31 wrote: different grind size will impact the size in basket and the fluffier stuff at 16g may be same height as 18g
If you know the recommended dose for your basket then that's really all you need to razor to find, so you may not need to use it again. The reason I suggest using the razor is you mentioned that some of your initial doses it didn't reach the razor, which suggests you are under dosing for your basket.
If you don't have an accurate scale, you will find using the razor more useful to get consistency throughout a bag of beans as opposed to portentially being 0.9g out on a dose. As others have mentioned, dosing by volume will not be as accurate as dosing by weight - although personally I have found negligible deviation in measured weight when using the same volume post-tamping measured with the razor - but until you get a decent scale I would consider using something so you know your dosing the same amount each time.
