Hand Cranked Grinder Static Solution - Page 2
- Bluecold
Or, 'as long as other manufacturers don't have anything, we don't need to embark on an expensive r&d project'ira wrote:If it was simple or even reasonable I'm sure they would.
LMWDP #232
If you spend some time searching anti-static solutions you will find that there is a whole industry dedicated to this problem. Answers exist, but they are rarely small or inexpensive. Adding a small fan and a very reliable high voltage source to a grinder along with all the changes to make it work is completely silly for a shop grinder that grinds one shot every 2 minutes. Mostly because I'd guess that 95% of the end users would not care or notice and the price increase would cost market share. A distilled water reservoir that dispensed on drop onto a heated surface might work, but anything with water requires maintenance, distilled water and additional work on corrosion protection. Likely the reservoir would just be left empty or a couple of fills of bad tap water and it would be dead.
If you think it's simple, why no propose a solution. The least expensive I can think of for a shop grinder would be a double wall hopper with a perforated inner wall and the ability to slide a damp pad between the walls to raise the moisture level in the hopper. But you'd only want to do that if you empty the hopper at least daily. Might work perfect or maybe not at all. Good 3D printer project for someone.
Ira
Ira
- grog
I don't understand why people are so offended at the concept of RDT. It's easy, it works, and it adds all of 1 second to your workflow. I have grinders that I've used RDT with for multiple shots a day for several years and they show no ill effects. Why is this bad?
LMWDP #514
Another vote for RDT! I'm a user and believer.
LMWDP #581 .......... May your roasts, grinds, and pulls be the best!
RDT is indeed very simple with no negative effects and much cheaper then all of the other solutions. Having burrs that are broken in does also help. I used RDT for the first year on my EG-1 and stopped using it after that as static wasn't a biog problem anymore. Some coffee oils on the burrs also do a great job as my blind shaker is crazy static for a week when I've cleaned it and stops being static once you see some coffee oils build up.
I can get huge static issues with some beans (electric or manual grinding) and get none with other beans 2 minutes later.
Water will explain a grinder issue. No effects using it will explain a roasting issue.
