Grind size
Hello,
I've bought a machine but I not the grinder yet.
If I bought the beans espresso grind, will it work or I'll over or under extracted shots.
What do you recommend me to do in the meantime?
Thank you
Thank you
- another_jim
Cans of Illy. It's the only preground coffee that works with a real espresso machine.
Jim Schulman
- iploya
And since you cannot control the grind size with this approach, you still can adjust dose up or down, which it seems like gives you some ability to dial in an extraction that will work for you.
