Getting the most out of an EK43s and La Marzocco Linea Mini - Page 2
- Shawnaks5
You can restrict your flow by installing the .6mm Gicleur. You can find it here:
https://www.voltagerestaurantsupply.com ... ur-l087gi6
I installed this in my LMLM and never looked back.
You can adjust the pump pressure as well. Here is a screen shot from the manual with instructions on how to do so:
- Shawnaks5
At the end of the day you have to experiment to find what you like best. Just because the shot may look bad doesn't mean it tastes bad. Before I did any modifications to my LMLM I had a stock EK43s and was able to choke the machine easily. I found that for me shots in the 1:2.5 to 1:3 range tasted the best for the coffees I was using.JonathanMichael wrote:Erik,
Thanks for the feedback. I wish there was a way to dial back flow/pressure but I'm not aware of any.
In general, have you found shorter shot times to be preferable?
I think verifying the alignment is a good idea and puck prep makes a HUGE difference. I settled on two baskets: Ridgeless 18g VST and this one from espresso parts:
https://www.espressoparts.com/products/ ... ter-basket
Really love the espresso parts basket. I think it allows for a better extraction with lighter roasts and it will hold more than 14g.
This is so helpful! I wasn't aware of this ability to adjust pump pressure. So do you just turn it down to a lower pressure? Or do you manipulate it as the shot is pulled?
Thank you so much
Thank you so much
You would reduce it to a lower pressure and leave it as it's inside the machine. Best would be to have a Scace device or build something to measure what pressure you're at. I like a 6,5 bar pressure as it gives me around 6 bar with a puck. Could try 7 and 8 bars as well. It's easier to get a good extraction in my experience with lower pressures with more unimodal type grinds, but 9 bars is probably OK too. But I wouldn't have it set to 3 bars so it's good to have something to measure with.
The smaller gicleur also should build up the pressure a little slower helping the preinfusion of the puck a little rather than it being blasted with water.
I like a slightly fast flow, 2+ gram/sec around the middle of the shots total weight, but it probably depends a little. I don't think 1g/sec and below is the best flow for EK burrs.
I need to give this a try. Maybe I can find someone who will let me borrow a Scace.
