I was wondering what people's opinion are about this.
If you keep the ratios proper, what effect does increasing the dose have on the taste of the shot? I have been experimenting but to be quite frank, I have burned through a lot of coffee (the amount I can afford) and am down to just asking questions. If you increase the dose does it increase bitterness? Acidity? Sweetness?
Just starting to get some reasonably decent shots
Thanks
Randy
All else equal, meaning truly all else's equal... it should only change the amount of your beverage...
Personally. I think that may ring true with VSTs but Jim S found that the bigger baskets had a different "punch" than the smaller as those had a "softer" taste..
Can't recall but it may also have something to do with the rate at which the cup cools..
When dialing in, once I've gotten the shot "balanced", I have a "bland <---> aggressive" scale that I use when I log my shots. Keeping the same brew ratio, if I find a shot too aggressive I drop the dose, if I find it too boring I will increase the dose. If it changes the flow rate too much I will either change baskets or change the grind to get the flow rate back where I want it.
