E61 Headspace Test and VST Basket Size
In the process of learning and troubleshooting my technique on my Profitec 600 I've been looking at puck thickness in regards to dose and headspace. I was a little surprised to find that on my machine with a VST 18g basket and 18g dose and an IMS shower screen installed I was getting a very deep impression in the tamped bed with a nickle test. Even at a 17.5g dose it is almost the full thickness of the coin. I could drop down to 17g but I'm wondering if this is normal and related to the fact that I'm tamping fairly lightly (~4-5lbs / compressed puck is at the top of the ridgeline of the basket) or if something seems off? I'd rather not give up concentration of flavours as I don't find the shots I'm getting to be too strong for my taste.
Does a VST 20g basket fit in a spouted Profitec portafilter? I could try one of those with a 19g dose. Does that make sense?
I have been doing lots of 19g doses in the 20g VST basket with the IMS shower screen. Mainly because I do light beans and I could grind finer with same flow and get higher extractions, it worked great for me, although I used low pressure but that may also be because light roasted dense beans ground in unimodal EK43 tend to go through really fast at the end and the setting I found the highest extractions and clearest taste profiles, and do spritz easily in a VST. I do prefer the 20g VST over the 18g VST but that might change when I get my Bianca as profiling can make a difference in extractions there. And 20g MIGHT be too deep a coffee bed for good even extractions anyways so try it out.
Appreciate you sharing your experience. Does the 20g basket fit in your spouted portafilter or just in the bottomless?
The 20 did fit in the regular double spouted ECM portafilter I had, and I have read it fits the Bianca too, but I think 20g is max basket size for most. I really like the cleanliness of the bottomless so don't use spouts other than for backflushing.
My 20g vst basket does not fit into my Profitec double portafilter.
Family, coffee and fun.
Okay, a bit conflicting. I guess maybe the ECM double PF could be different than the Profitec.
I won't buy it if it only fits in the bottomless. Some mornings I just don't want the potential for extra cleanup.
Can't speak to the basket fit for a profitec portafilters, but I do use a 20g VST basket for 18g shots. I found that my dose was overfilling and making a mess with my 18g VST basket.
This is on a VBM Domobar Jr with IMS shower screen.
I started tamping harder and now I can get a proper nickle test with 18g in the 18g VST basket. The issue is when I tamp harder I'm less likely to be level.
