Best way to remove less then a gram of coffee?
- slipchuck
Let's say I have 18.3 grams and want an end result of 18.0. What is the best method of removing the extra grinds without making a big disruption of your coffee in the portafilter?
Randy
Randy
Just take grounds out in small pinches, weigh, then distribute. No risk of disrupting distribution if you weigh first.
- sweaner
Why?slipchuck wrote:Let's say I have 18.3 grams and want an end result of 18.0. What is the best method of removing the extra grinds without making a big disruption of your coffee in the portafilter?
Randy
Scott
LMWDP #248
LMWDP #248
- BaristaBoy E61
I use a 'Curette', a long, 2-sided small 'spoon' used in chemistry labs.
The smaller end is also perfect for sampling a single drop of espresso, at anytime during the extraction, from a naked portafilter without seriously affecting the shot.
- Peppersass
- Supporter ❤
Unless you're doing scientific measurements (e.g., trying to calculate extraction yield), don't remove the excess and pull a tad more beverage (e.g., 0.6g more for a Normale.) Less than 0.5g will have minimal effect on flow rate and taste in the cup.slipchuck wrote:Let's say I have 18.3 grams and want an end result of 18.0. What is the best method of removing the extra grinds without making a big disruption of your coffee in the portafilter?
Since you are referencing removing such a small amount, be sure to lift the portafilter from the scale and set it back down gently. The most consistent accuracy is obtained by weighing in the same direction. i.e. Always weighing on an increasing value will be more accurate than weighing on the increase initially and then subtracting while on the scale platform. This applies to both electronic and balance beam scales.
Suffering from EAS (Espresso Acquisition Syndrome)
LMWDP #586
LMWDP #586
- HB
- Admin
I do that all the time using the "bowed finger" swipe (see Grounds Distribution Technique for more details). Essentially it's the Stockfleths Move for Dummies with your finger bowed downward instead of straight. It's limited to small reductions, right around the 0.3 grams range you mentioned. For the coordination challenged, a swipe with the doser lid works too.slipchuck wrote:What is the best method of removing the extra grinds without making a big disruption of your coffee in the portafilter?
