Anyone get ashiness when icing down coffee/espresso?
Hey everyone, summer is coming and just had my first iced espresso/latte this past weekend. Just a nice double shot (which tastes great hot), a 1/2 tsp sugar, cooled with some milk, then poured over ice. This particular espresso was Highwire Core, pulled at 199, 14g in and 20g out.
I've noticed with my espressos when i ice them down it seems to bring out a ashy note. Anyone experience this?
- Boldjava
If they have a Brazil in there, it might have been roasted a tad long.jasonmolinari wrote:Hey everyone...
LMWDP #339
LMWDP #339
This doesn't seem related to a single blend. I'm pretty sure the problem is me...trying to figure out how to fix it
- SlowRain
I'm not sure it is you. I've found I can drink lots of coffees hot and they taste fine, but as soon as I make iced coffee, they taste burnt. There have been two solutions that have worked for me. 1.) Cool the coffee down slowly. Either make it a few hours ahead of time and let it cool to room temperature naturally, then add ice; or else immerse the coffee an ice bath and stir like crazy. 2.) Use light roasted coffee for iced coffee.
I do number two. I find light roasted coffees very refreshing when iced, but just ho-hum when hot. However, I've never done it with iced espresso. If you want iced espresso, I recommend buying a Nomad espresso machine and using cool water to brew. Now, THAT'S refreshing espresso!
- weebit_nutty
I find coffee tastes vastly different at different temperatures. It's kind of a blessing in disguise because in every roast I've ever drank, there's always a temperature that is optimal for its flavor, so if I don't particularly like it, I'll try it at a different temp ( usually cooler) it is almost always improved.
As to this notion of ashiness in icing your brew, I've never gotten that. I'm wondering if you have stale/freezer burnt ice. I always use clear store-bought ice. Ice-maker ice from home fridges are never very good tasting, and most are downright bad.
What does the shot taste like at room temp ( no ice etc ) as coffee cools , its flavours open up , perhaps the warmer temp of the espresso is just masking a strong bitter shot .....this then reveals itself at a lower temp , where you are able to taste more flavour and less " hot "
Especially if you don't use and replenish the carbon filter in the refrigerator. Straight tap water ice can be very unpleasant.weebit_nutty wrote:Ice-maker ice from home fridges are never very good tasting, and most are downright bad.
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
Alex
Resting period can sometimes help mute the Ashiness. Try pulling again in 5 days and see if there is improvement.Boldjava wrote:If they have a Brazil in there, it might have been roasted a tad long.
@slowrain, yes! exactly. I find similar issues with iced brewed coffee too (clever dripper, aeropress). will try cooling slower.
My ice is fresh and tastes good from a fridge with a carbon filter. THat's not the problem
I will let the coffee cool to room temp and try it, and also let it rest a little longer.
thanks guys.
thanks guys.
- Sponsor
This is the reason why I like to pull a cold brew espresso occasionally. It cools very nicely. Hot coffee or espresso cools unpredictably to me.
I use room temp water and pre brew for 10-30 minutes then pull the shot as normal. You may try to pre wet the puck for several minutes, then lock into a cold machine and pull. I do mine differently but this may work on other machines.
