7 gram single shot?? Mission impossible!
giboja
#1: Post by giboja »
Hi all
I need help to achieve 7-9 grams single shot espresso.
It can be 9 gramm, no problem, but it should be easy simple solution.
I have new Lelit Elizabeth, my first manual/semi manual espresso machine and cant get anywhere near consistent single shot 7-9 gramm espresso.
Main problem is tamping, I have 2 single dose baskets:
Original Lelit single ridgeless, 7 grams basket
and
IMS Marzocco Competition Filter Basket 7/9g - B701TH26.5E
Tampers are:
58,5 flat
57 flat
49.5 flat
If I dose Lelit 7 gram basket enough for 57-58.5 tamper to be able to compress the coffee (9gramm app), it stacks to shower screen.
If I dose less, tamper just cant get deep enough in basket to compress the coffee.
With marzocco ridged basket situation is the quite the same.
I try to first tamp with 58 tamper and with 49 tamper in center and that solution works the best but it is inconvenient and hard to repeat the sam.
I did read about LM basket and funnel but that is again too complicated.
Is there any other solution for simple single shot espresso or I bought wrong machine??
Thanks
Jeff
#2: Post by Jeff »
The problem is likely not the machine but the basket and tamper.
See, for example, What's the best single basket.
giboja (original poster)
#3: Post by giboja (original poster) »
I did read that thread but cant see any new solution.
Maybe Reg Barber C-Flat or convex tamper can help a little to get rid of double tamping?
#4: Post by giboja (original poster) »
Jeff wrote:The problem is likely not the machine but the basket and tamper.
How it is done in Italy where all barista just dose and tamp single dose (7-9 grams) just like that and all is good?
Maybe commercial machine have more head space for puck not to touch shower screen?
Jeff
#5: Post by Jeff »
Getting a good shot from any current, pump-driven, home machine with a dose around 7 g is a challenge. Even with the better basket and tamper combinations.
If that is your goal, a mid- or late 20th century, home lever like a Caravel may do better. They were designed for a more petite shot, as was the practice then.
Classic, Italian roasts are also very different in their composition and roast than "specialty" coffee. There's a great thread on them at The hunt for best Italian roasted coffee beans
Otherwise I'd stick with roughly 15 g or larger doses in a conventional or "precision" basket, perhaps a bit less in the old-school "Faema" baskets.
#6: Post by giboja (original poster) »
That is bad news for me
I am used to have 3 esspreso in the first hour in the morning.
It was Jura E8, superautomatic, 10 gram, 30ml per cup, much weaker esspreso cofein and taste wise.
If I go with 15 gramm x 3 it will be too much cofein for me plus, my wife do not like strong espresso.
Is there anyone with experience with Decent 7 gramm basket??
Auctor
#7: Post by Auctor »
giboja wrote:Is there anyone with experience with Decent 7 gramm basket??
I purchased the Decent 10/12. The main difference I saw from Decent and the IMS 8/10 is the lack of sloped sidewalls in the Decent basket, which allowed you to get the same tamping workflow from a traditional 58mm tamper. The Decent basket is also shorter. I had some good luck with the Decent basket, but it suffered from a thinner puck than a traditional 14-18g basket, leading to incredible sensitivity to channeling and over extraction.
I recently switched back my to ECM double basket, and dose 12-13 grams (depending on roast). My 12 gram medium/dark extracts 18 grams in 20-24 seconds, and looks and tastes like perfection, with a great extraction out of the bottomless. A 12g light roast can yield 24g out in 28-32 seconds with an appropriate preinfusion, and isn't significantly more coffee (in grams) than what I was getting from a 9/10 gram dose.
I've since given up on the super small doses (<9 grams).
#8: Post by giboja (original poster) »
Auctor
#9: Post by Auctor »
It doesn't look like it. Unfortunately there are no markings on my basket - i can only tell you that it came stock with my Synchronika, and the basket walls aren't completely flat like the Decent. In analyzing three baskets more carefully (IMS 8/10, Decent 10/12, and the ECM Double), I can tell you that the IMS has the least amount of holes and the greatest sloping walls. But it's "taller" than the Decent 10/12, which has no sloped walls but the MOST holes. This is just me extrapolating now, but it seems what works for the ECM is a very slight sloping and a medium number of holes, combined with a nice puck height.
Edit: I think I found a pic of the ECM basket.
https://coffeeforums.co.uk/topic/40239- ... ent=573299
JohanR
#10: Post by JohanR »
giboja wrote: I did read about LM basket and funnel but that is again too complicated.
In my mind a VST 7 gram basket or LM1 with a 41 mm tamper is the way to go for single shots. And you do not have to have a funnel. This will also make it possible to use the same grind setting as for a double in a 14 or 15 gram basket. (The area of a 58 mm basket is twice the area of a 41 mm one.)
Johan
