The $2.50 WDT tool - revisited - let's see yours
So I wanted to quietly post this to this thread just to give it some company, but "the system" made me start a new one so here goes. I think his looks better but I think I had more fun making mine! It's also a whisk conversion. If you did one too, Post yours!
LMWDP #581 .......... May your roasts, grinds, and pulls be the best!
Where on earth did you find a bottle of patron for $2.00!?Tonefish wrote:So I wanted to quietly post this to this thread just to give it some company, but "the system" made me start a new one so here goes. I think his looks better but I think I had more fun making mine! It's also a whisk conversion. If you did one too, Post yours! <image>
Hah! Silver Coin Margaritas are my favorite (well, 2nd favorite) summer bev, so I've got lots of those corks around.
It would be interesting to try a version of that one with more toothpicks. One of the things I really like about the newer ones I've made with more "fingers" is that the process is much quicker.ojt wrote:Heh,
I have a similar, even cheaper solution. Cheaper at least in the sense that I really put zero effort on it so far
<image>
Will work on this when I have time... but, it does what it needs to do, at least so far.
- mkrissel
Cake tester. $3.40. Works great!
Ateco Cake Tester https://www.amazon.com/dp/B0018AHVSU/re ... xBb0E20DD4
Yea, that's what I used before. Does a good job but takes a lot longer.
Looks great! Thanks for the part info too. I didn't know they sold things like that. I've been prepping for a drilled and turned one too and will definitely check these out.Moxiechef wrote:This is my current prototype. Wanted to make sure it worked before turning a handle on the lathe and the buying a drill bit to fit the wire shafts.
It works great!!
