What is the latest on the storage of coffee greens? - Page 6
- networkcrasher
Damn. So sealed storage (airtight "Tupperware" style container) in a wine cellar at 57* and 60%RH won't work? Looks like a lot of folks might get coffee for an extra Christmas surprise this year!
- Compass Coffee
- Sponsor
Not saying that at all. First most people don't have close to that level of controlled environment greens storage. Second while it works quite well it won't keep greens as fresh as long as vacuum sealed and frozen. For normal annual crop greens rotation likely quite adequate, if not optimal.Damn. So sealed storage (airtight "Tupperware" style container) in a wine cellar at 57* and 60%RH won't work? Looks like a lot of folks might get coffee for an extra Christmas surprise this year!
Mike McGinness, Head Bean (Owner/Roast Master)
http://www.CompassCoffeeRoasting.com
- networkcrasher
- farmroast
- farmroast
- networkcrasher
Thanks, but I was more considering the response to whether the vacuum makes a difference or if the seal does. I understand the residual air/oxygen in the container would cause issue, but after time, in a sealed environment, would the impact be negligible after the residual gas makes its impact?
- Compass Coffee
- Sponsor
You answered your own question. If residual air/oxygen causes an issue, then evacuating more air/oxygen via vacuum would obviously make a difference. Irrelevant if after time in sealed environment no further damage would be done from no additional air/oxygen.Thanks, but I was more considering the response to whether the vacuum makes a difference or if the seal does. I understand the residual air/oxygen in the container would cause issue, but after time, in a sealed environment, would the impact be negligible after the residual gas makes its impact?
That said I have not done comparisons vac' freezing greens versus simple sealed container freezing greens. I had a FoodSaver before I started home roasting 8 years ago so always vac.
Vac'd frozen versus vac'd room temp does make a definite difference long term storage. The longer the storage, the greater the difference.
- cannonfodder (original poster)
I have been vac packing and deep freezing my greens for a while now, works very good for me.
- GC7
