What coffees are you blending? - Theory and Practice - Page 8
i'm sure you could taste a contribution of flavor at 10/15% but from what i've read, lower amounts like that can run into some problems with consistency due to the statistical risk of getting an uneven distribution in any given cup/shotChert wrote:What is the minimum contribution that makes a difference in the cup?
- Chert
Good point. two color m&ms could demonstrate that. And how would yellow peanut M&M's at 10% distribute into green plain m&m's?
Like peaberries mixed with pacamara. Wouldn't coffee seeds sort out if not sized similar in a blend more than similar sized seeds?
LMWDP #198
- CarefreeBuzzBuzz (original poster)
I never go below a third as I fear they won't mix together well enough.
I blend by the cup these days so distribution isn't much of an issue. I can sometimes detect as little as 10% of one bean in particular but its got a really unique profile. Usually I'm dumb up to about 20-25%. Of course like most things, its dependent on the beans in question.
One of my pro-roaster buddies uses as little as 10% of one coffee in a 5-bean blend for their house espresso. At one time I thought that may be too many beans in a blend but after subsequent consideration its more like 2 similar beans and 2 other similar beans-an additional of each to mask/mirror variances, then the 5th/3rd outlier at 10%.
Another pro-roaster uses 3 beans in a blend-50-30-20. The base is a Brazil, the 20% is a heavy blueberry African natural, with the 30% a fairly bright Guat.
I wouldn't think that in a business use a blend developer would select beans that wouldn't mix well or consistently, ie the Peaberry Vs. Pacamara thing.
- Chert
Blending is great.
Pouring beans together post roast gives fab aroma; added perk.
LMWDP #198
By the way, good call from the several people here I saw mention Daterra Sweet Blue as a good base brazil for blending stuff -- tried a few batches now and it really is an ideal comforting base.
Has anyone tried Brazil Dry Process Cafeicultores de Minas from SM for blending?
I've been trying the 'super' roast single-origin thing - but worrying about my grind settings. The two different roast levels require significantly different grind settings. If I swap grind settings between the roasts I get a 10-second pull and a 2-minute pull - very non-optimal and taste not-so-good. So, as I fish around for the right grind setting for a mix of roast levels, I wonder if all I'm doing is counterbalancing two otherwise unpleasant tastes. Am I doing it wrong?Brewzologist wrote:Does anyone ever blend the same coffee using two different roast levels to get a 'super' single-origin blend?
- Boldjava
Our Minnesota group is gathering on Zoom this weekend, making it a Mokka Java day. I am blending a SM Java and a Yemen natural, neither of which is outstanding in their own virtues.
Together? They sing. The Yemen has a soprano brightness and the Java offers the bass. They blend without pronounced notes from either one -- balanced cup which is great.
Been trying different ratios, Java/Yemen. 58/42 is just right.
LMWDP #339
LMWDP #339
Another Wush Wush blend a hit this morning.
50/50
Ethiopian Wush Wush Natural
Columbia Palo Roas Sugarcane Decaf
50/50
