USB Isolator recommendations wanted
I'm seeking recommendations for a USB Isolator.
My laptop battery is getting a bit old and I want to get off of battery power and plugin. I'll use it between my Lenovo laptop and my Mill City 500g with MODBUS.
Does anyone have a recommendation for a good USB Isolator that works?
David Austin
I'm Using a Singxer SU1 for audio , but for plain USB I would imagine any isolator works. I see optocoupler based USB isolators for around 8 bucks.
LMWDP #483
- CarefreeBuzzBuzz
Do you know for sure that plugging in is giving you noise with the Modbus. Interesting, when did you ditch phidgets and why?daustin777 wrote:I'm seeking recommendations for a USB Isolator.
I just received my roaster at the beginning of September. I didn't ditch the phidget, Mill City did. I was expecting to get a phidget but when I told them it was missing they said it was now MODBUS and integrated into the machine with a mounted USB jack. They couldn't tell me much more, not even the settings I needed for connecting to Artisan, though I think I may have figured it out via trial and error.
When doing a MODBUS scan, I'm missing some info when the power supply is plugged-in. If I unplug, all the info is there. So, I assume I need an isolator.
David Austin
- CarefreeBuzzBuzz
Thanks! I'll take a look!
David Austin
