Start of 1C
Hi All,
When I roast I usually get 1 weak pop, followed by 30 second (plus or minus) until the next pop. Then 1C really gets rolling.
Is that first weak pop the start of 1C or do I wait (for timing purposes, etc) until the later more vigorous cracks?
Thanks!
Eric
Thanks!
Eric
There are typically a few outliers early on, then when you hear 3 or more consecutive pops, that's considered real 1C.
I normally start the timer after I've heard a few cracks, and the pattern can vary a bit between different types of beans.
Whichever way you choose to do it, it's best to stick to that method for repeatability.
Thanks. That's quite clear and makes a lot of sense given my experience with my roasts.
Happy roasting!
Eric
Happy roasting!
Eric
Yes, after a few pops, as others have said. Note that the early pop phenomenon is sometimes worse with blends. You might get an outlier or two, then some more pops, then a little null, followed by more vigorous popping. It all depends on the type and age of the beans in your blend.
- another_jim
I don't think 1st (or 2nd) crack start is a good benchmark for timing. It varies by coffee, by roast weight, and by the length of the prior roast. I start my timing at 190C (375F), which for my thermometry is about 20 to 45 seconds (4 to 8 C) before the first crack starts for most of my coffees.
Jim Schulman
Jim shared his method with me, and I have found it to be bang on for consistent results on my M3. Thank you Jim for your advice!
Dave Brown
Dave Brown
I'm curious how you determine your point to drop? Using a fixed temp makes sense indeed, just wondering if it's temperature based or time (and if time how given the variability of FC)another_jim wrote:I don't think 1st (or 2nd) crack start is a good benchmark for timing. It varies by coffee, by roast weight, and by the length of the prior roast. I start my timing at 190C (375F), which for my thermometry is about 20 to 45 seconds (4 to 8 C) before the first crack starts for most of my coffees.
LMWDP #483
- another_jim
For my first few roasts, I base the drop on smell (no more irritants for the very lightest roasts, various degrees of caramel and toastiness for everything else. If you cook with a wok or saute pan, you'll be good at this.). Once I have that, I repeat the time. Repeating temperature would work the same way, since I keep a very constant ET; time is more convenient on my set up.
Jim Schulman
I gave it a go, a bit uneasy as a fixed amount of time somehow feels more like being in control....but in fact it is not as time is only a surrogate parameter for results....will know more i a few days after a good rest (at 207 or so drop temp, funny that THAT was consistent with my previous 'system' of looking at time post FC and drop temp)
LMWDP #483
