RTD going crazy
N6GQ
#1: Post by N6GQ »
So I have 3 RTDs connected to Artisan via Phidgets (got the RTDs from Phidgets). They're about 6 months old. They've worked great but the last few roasts I've had issues. The ΔBT probe gets erratic a few minutes into the roast. It fluctuates like 50C - very bogus data.
Wondering if this is how RTDs typically fail? I imagine I could do some testing to see what's bad - the RTD, or the Phidget device.
Thoughts?
LMWDP #614
Marcelnl
#2: Post by Marcelnl »
do you update the phidgets software/firmware?
what computer do you use, is it on the PSU ?
LMWDP #483
N6GQ (original poster)
#3: Post by N6GQ (original poster) » replying to Marcelnl »
Haven't updated lately but I will.
I use a Lenovo laptop running Windows 10.
This has all been working perfectly for 6 months or so, then the one RTD started acting up.
And ya, it's plugged in.
LMWDP #614
ira
#4: Post by ira »
Well, swap the problem RTD with one of the working ones at the board and see if the problem moves channels. That answers the question of is that RTD the problem.
#5: Post by N6GQ (original poster) » replying to ira »
Yep, was planning on doing that on my next roast...thanks.
LMWDP #614
Marcelnl
#6: Post by Marcelnl »
just gibve updating a try, and then using the laptop without the power brick...there are plenty of folks needing to use a USB isolator to dial down noise.
just my 2 cts.
LMWDP #483
#7: Post by N6GQ (original poster) » replying to Marcelnl »
Roger, will try that, thanks.
LMWDP #614
Marcelnl
#8: Post by Marcelnl » replying to N6GQ »
Hope it helps, RTDs can fail too....mine work flawlessly and I have only seen few reports of an RTD failing but it can happen!
LMWDP #483
#9: Post by N6GQ (original poster) »
Thanks, I'll report back with what I learn on the next roast...
LMWDP #614
Marcelnl
#10: Post by Marcelnl »
it's a steep learning curve ...but there is an end to it! Just keep at it and you'll master the process!
LMWDP #483
