Rob Hoos' Tipping and its Avoidance: a Style Guide for Coffee Roasters (PDF) - Page 3
- Brewzologist
Thanks for testing this Flint. I toyed around with it by placing a probe up the backside of the roaster too, but I think the design of the Huky doesn't really allow for isolating incoming airflow from the burner so I didn't go anywhere with it. I mostly use ambient temp from my Phidget setup.Chert wrote: I should study that pdf or othwrwise try to get an idea of best placement . Rather than 12 o'clock I had intended, the lower non-drilled mount is more like 6 o'clock and below the axis of rotation.
- Chert
I will hope some questions come up like that during the iteration session. I'm curious could you elaborate about the Huky airflow as you see it?Brewzologist wrote:Thanks for testing this Flint. I toyed around with it by placing a probe up the backside of the roaster too, but I think the design of the Huky doesn't really allow for isolating incoming airflow from the burner so I didn't go anywhere with it. I mostly use ambient temp from my Phidget setup.
I had one In the outlet a couple years ago, but learned little from that
LMWDP #198
- Brewzologist
PM'd you so we don't hijack this thread.Chert wrote:I will hope some questions come up like that during the iteration session. I'm curious could you elaborate about the Huky airflow as you see it? I had one In the outlet a couple years ago, but learned little from that
>If you haven't checked out Rob's Iteration project, I highly recommend it https://www.iteration.coffee/
Thanks for the link! Rob's book is there in digital form for $20! That's a no-brainer, something I'm really good at.
- GC7
Thank you for the information about Rob's book. I just picked up a digital copy and its in the printer now.Frankc1450 wrote:>If you haven't checked out Rob's Iteration project, I highly recommend it https://www.iteration.coffee/
Am I doing something wrong that tipping hasn't ever been an issue? Is it common?
- Supporter ❤
May be a case of you don't know you have it until you start looking closely. Mild tipping doesn't present much in the cup, but we still strive for better roasts.
No doubt. The pictures online seem hard to miss, but I presume it's a spectrum like most things. I doubt my palate is discriminating enough to notice.
- mkane
I made a nice thermocouple bracket to measure incoming air. Temps are way behind, 300°thereabouts using a 5mm probe. I'll switch it to a 2mm unit that's lying somewhere here.
Using the latest Artisan software makes it very difficult to select the right 'extras'
