Rob Hoos Interview on Coffee Roasting With Roast Rebels
The forum software suggested starting a new thread rather than extending the existing one in a new direction.
The interview is information-dense and about an hour long. The snippets from my notes would have been in the first 5 minutes. The interview is the best information I have encountered so far -- even if that is unique to me, as in it just hit 'right' for what I needed to hear, I encourage anyone with an interest in roasting to watch it. Hoos has a soft place in his heart for home roaster. He might have said so in that interview. It comes through either way.
(By the way, I morphed the information in the interview to fit my roasting situation and have no recollection of discussion about dropping the roasts at a specific temperature, although I have seen unrelated videos where that is implied. It may be in that interview or it may not.)
I stopped taking notes somewhere in the middle, maybe 2/3 of the way through. The discussion had moved to selecting commercial roasting machines - which is just not relevant to my needs.
After this the discussion moved to roast defects, some objective (scorching, tipping, facing, chipping), some subjective (baking, over-roasting, under-roasting, over-developed, under-developed). My notes there are closer to transcriptions. IIRC after roast defects the discussion moved to selecting a roasting machine.
Here is a little more teaser content, please be prepared my typos, non-sequiturs, awkward and/or incomplete wording.
How to roast better coffee - an interview with Rob Hoos
Channel: Coffee Roasting With Roast Rebels (55:07)
Interviewer: Ingo Albrecht
@pcofftenyo, Please regard those dozen lines of notes as teaser content!pcofftenyo wrote:(from post #61 of a different thread.) Thanks for summarizing the Hoos interview. And thanks to both of you posting up your curves.
In response to question: What are the most important decision for roaster
Hoos cites and details research shared by Morten Münchow (researcher in Copenhagen)
• biggest drivers of flavor from roaster
#1 roast color
#2 development time
#3 time to 1C
- biggest change you can make is to change the final color of the roasted coffee
- whole bean color is primarily about temperature exposure
- average color of ground beans is affected by length of development time
◊ short development time -> lighter color (whole and ground bean)
◊ longer development time decreases the difference between whole and ground
bean colors. It brings ground bean color closer to whole bean color.
- development time plays a huge role in flavor of coffee
◊ +/- 10 seconds for consistency
- increasing time pre-1C increases body and complexity (caramel, nuts, etc)
- increasing time to 1C decreases clarity and floral notes
• green coffee has a huge influence on final result
- "can't polish a turd"
◊ 80pt green coffee is hard to roast such that it reaches 80pt result
with very little room for error
◊ 90pt green coffee can be roasted imperfectly and still taste good
- higher altitude coffees tend to be more acidic
- lower altitude coffee tend to be less acidic
- processing overrides a lot, giant generalizations are
◊ natural process overrides cultivar and terroir
◊ naturals tend to be fruit-forward, earthy, chocolate-y, more body
◊ washed process coffees tend to be citric and malic, more floral, lower body
◊ honey-processed coffee tend to be middle-ground between natural and washed
• differences in roasting natural process vs washed coffee
- natural process
◊ shorter development time 1:15 to 1:30
◊ roast naturals a little bit lighter than washed
◊ Joe Morroco says "pretend natural process are already a little bit roasted"
- washed process
◊ longer development time 1:30 to 2:00
◊ shorter development time on washed coffee tends toward vegetal flavors
• generally do not roast below 11% weight loss
Roasting for espresso
• espresso extracts a lot of acidity
• espresso tends toward under-extraction.
• stretch the roast to get more or at least different maillard by-products
- stretch the time to 1C
• roast for more complexity and more body
• use longer development time to neutralize some acidity;
• roasting darker can help bring balance
• low-end weight loss for espresso: 13%-14%
• high end weight loss: sky is the limit, depending on personal taste
Developing even color in a roast
• stretching development time helps even inside-outside color evenness
Comparing roasts by weight loss
more than .5% roast to roast delta weight loss means changes in flavor
.25% weight loss is goal for roast-to-roast consistentcy
11%-13% weight loss = light roast
13%-16% weight loss = medium roast
16%-18% weight loss = dark roast
18%-22% weight loss = extra dark roast
Bean Density
• how to measure bean density...
equipment needed
50ml graduated cylinder
gram scale that reads to 1/100g
technique
fill graduated cylinder with 40ml water
tare
add beans to get to 50ml
result: know how many grams it takes for 10ml
multiply that number by 100 to get g/l
• low density coffee has increased risk of roast defects if fast roast
• high density coffee - roast as fast or slow as you want
• low density: 1120 g/l <- soft coffee, be gentle while roasting
• high density: 1160 to 1200 g/l <- unlikely to push it so far as to cause tipping
Moisture Content and Moisture Meters
• Good resellers will know the moisture content of the beans they sell. Otherwise
it is necessary to buy specialized equipment to measure moisture content. Low-end
meters are around $300.
• beans with moisture above 11.5% will spoil faster than beans with lower moisture
content. As a guess roast that coffee w/in 6 month
• Higher moisture levels require energy to roast. Beans with 11% water require
more energy to roast than beans with 10% water content.
Thanks for providing the link as well as some notes. I just ordered Rob's book on roasting so will report back when it arrives.
It would be interesting to have a series on roasters -both rebels and conventional -the only criteria is a sincere desire to produce good roasts. This could include comercial roasters and consultants. For example would be neat to compare roast profiles and 'roast philosphy' of say roasters who use primarily one level-type of roasting with minimal variation versus others who roast at a wide varety of levels. Could have a variety of roastering styles ad 'eras' represented... from Klatch, Black & White, Panther, Blue Bottle, Intellegesia, Marhsall Hance...and so forth. Not a competition or debate but rather simple a collection of roasting approaches and styles.
- LBIespresso
- Supporter ❤
Just watched it a second time. Thanks for posting this. I really liked it. Funny thing is I skipped looking at your notes until I came back to watch a second time. Very good summary!
The comment about naturals was the thing that stood out most to me.
LMWDP #580
Thanks for the link. I read Rob Hoos "Modulating the Flavor of Coffee" essay and didn't care for the presentation or the study method compared to Rao's polished literature. I haven't revisited his information since so this seems like a good way to dip the toe back in.
