Roasting Glossary of Terms and Acronyms
farmroast
#1: Post by farmroast »
ACRONYMS:
  • BT--Bean Temperature: as measured by thermocouple or thermometer in the bean mass.
    ET--Environmental Temperature: The environmental/air temperature in or around the roast chamber that relates to the average temperature the beans are being exposed to at a particular point in the roast.
    MET--Maximum Environmental Temperature: The maximum environmental temperature the beans are exposed to in the roast environment. Can also refer to the maximum ET the beans are exposed to during the roast.
    RoR-- Rate of Rise of BT degrees(C or F) rise/time(usually per minute)
    RoC-- Rate of Change of ET, positive or negative.
    TC--Thermocouple: A digital thermometer with a wire and probe or wire that is bare at the end with a bead tip or wrapped.
    TC4-- A Arduino based roast monitoring and controlling device developed by the homeroasting community TC4
WP-- Wet processed coffee
DP-- Dry processed coffee
TERMS:
  • Drop temperature: The ET at the time the beans enter the roaster.
    Turnaround Temperature: The BT reading at the point after the beans are dropped when the BT reading begins to increase/turnaround after dropping from the preheat temp.
    Dump: The point when the roast ends.
    Warming Phase: The initial phase of heat being applied to the beans.
    Drying Phase/Stage: The first part of the roast where the beans are dried to the proper level.
    Ramp Phase/Stage : The phase/stage after the drying up to 1st crack where the heat applied is generally increased. Maillard reactions are occurring and then sugars.
    First Crack: A popping sound similar to popcorn where moisture is released
    Second Crack: A snapping sound similar to rice krispies where co2 is released
    Conduction: Heat applied by direct contact
    Convection: Heat applied by air
    Radiant: Heat applied by radiance off of a surface, heating element, infra red heat
    Exothermic: Where the beans are releasing heat energy
    Endothermic: Where the beans are absorbing heat energy
LMWDP #167 "with coffee we create with wine we celebrate"
another_jim
#2: Post by another_jim »
Thanks
Jim Schulman
Versalab: maker and supplier of finest espresso equipment
Sponsored by Versalab
arriflex
#3: Post by arriflex »
It may be time to add:
ROR -- Rate of Rise: The velocity of Bean Temperature measured as degrees (C or F) per time division (usually one minute) More info here: Any way to have a meter display of the degrees rise/ min. rate?
drgary
#4: Post by drgary »
You might want to add BMP = Bean Mass Probe.
LMWDP#308
mcwresearch
#5: Post by mcwresearch »
I've seen "charge" and "drop" used interchangeably and I've also seen "drop" and "eject" used interchangeably.
Can anyone speak with authority on the correct usage of "drop" (if there is a "correct" usage)?
