Roast and Learn Together - March/April 2015 - Page 8
- NoStream
As my experiments with this bean come to a close, I'd just like to offer a brief final post. I wound up with a reasonably fast profile, with a hot charge, and plenty of heat early, declining throughout. Rao's rules held quite well. I was charging up at around 450-460 F BT and MET at first but have gradually scaled back a little to 430 as this coffee now shows a bit of aged character.
This roast had 12.13% weight loss. I'm trying out tastify, so I'll include my cupping results below as a product from it. 10:180, 204 F, 7.6 grind on my EK
I didn't note aged greens in my overall score and am not a frequent SCAA sheet user, so ignore the overall number given.
I also tried this as a V60-02 three days post. 12:204, 204 F. It was thoroughly tasty - delicate body, jasmine, lemongrass, lemonade, pristinely clean cane sugar, etc.
Espresso -
I pulled this from 30-50% brew ratios, ~8 bars, 200F at the grouphead, ultimately preferring it around 40% brew ratio (17 in, 42 out). Flavors included lots of sweet citrus, oolong tea, jasmine, buttercream, lemongrass, berry, and so on - very similar to the brewed coffee.
Espresso -
- TomC (original poster)
It's interesting, I basically did the same approach a few nights ago, with two different Ethiopian's I had saved in the chest freezer. I ran both the Gedeo Worka and the Grade 1 natural processed Yirg Kochore at profiles with very short roast times, with a much higher charge temp. The Gedeo Worka profile ended up being by far the best I ever had on that particular coffee. The Kochore was showing some age and although nice and floral, a bit tired (it didn't get vacuum sealed until it was several months old here). It was these two profiles that actually got me thinking about the "double" roast approach. I want to apply this sort of short profile to beans that are as evenly dry as possible.NoStream wrote:As my experiments with this bean come to a close, I'd just like to offer a brief final post. I wound up with a reasonably fast profile, with a hot charge, and plenty of heat early, declining throughout. Rao's rules held quite well. I was charging up at around 450-460 F BT and MET at first but have gradually scaled back a little to 430 as this coffee now shows a bit of aged character.
- NoStream
I can't imagine you'd have good results with a fast approach to a natural. Those sugars on the bean surface are just begging to scorch.
I think that's really interesting regarding the double-roast. I'll definitely try it next I roast - probably on this coffee, even, since I think I have enough of it for two more batches. I've had really good results with slow-start, fast-finish profiles for bringing out incredible sweetness and near-zero roast character, but they simply aren't soluble. So perhaps your approach can yield the solubility of a fast-start profile with the absolute cleanliness of a slow-start one? That would be great.
But that's exactly what I found. I think it's unique to the Quest, since there's barely any thermal mass to the roaster, the heat caves in when you charge anyway. I haven't found any detrimental effect yet. The coffee was far better the first two days than today's brew, I will say that much for sure. Could have been a blip on today's brew method, I'm not sure.NoStream wrote:I can't imagine you'd have good results with a fast approach to a natural. Those sugars on the bean surface are just begging to scorch.
I'm going to keep plugging away with short, hot profiles with limited post 1Cs roast time for a while. The double roast idea should theoretically help me start with evenly dry coffee that I can blast pretty hard and fast and save as much varietal character and sweetness as possible. I'll be excited to see your results too!NoStream wrote:I think that's really interesting regarding the double-roast. I'll definitely try it next I roast - probably on this coffee, even, since I think I have enough of it for two more batches. I've had really good results with slow-start, fast-finish profiles for bringing out incredible sweetness and near-zero roast character, but they simply aren't soluble. So perhaps your approach can yield the solubility of a fast-start profile with the absolute cleanliness of a slow-start one? That would be great.
- endlesscycles
Conductive moisture allows high heat input. Evaporative cooling protects the outer surface. Dy insulative cellulose will not transfer heat and will scorch / bake.TomC wrote:I'm going to keep plugging away with short, hot profiles with limited post 1Cs roast time for a while. The double roast idea should theoretically help me start with evenly dry coffee that I can blast pretty hard and fast and save as much varietal character and sweetness as possible. I'll be excited to see your results too!
-Marshall Hance
Asheville, NC
Asheville, NC
endlesscycles wrote:Conductive moisture allows high heat input.....
You should probably try to describe what you mean with real terms. Conductive moisture isn't a real or scientific term. But I understand the rest of your comment and I'm not sure if I agree. Like it's been covered elsewhere (Illy), even fully roasted coffee contains moisture, so it's not like the beans are completely dry, just hopefully more evenly "dry".
- [creative nickname]
I also tried the hot charge, fast roast approach with the Gedeo Worka DP, and got fantastic results, with no apparent scorching. When I get a chance I'll post the details in the January R&L thread.
LMWDP #435
- endlesscycles
Those are real terms. Moisture is a conductor of heat... hence it's use in heating and cooling systems. Cellulose is often used as insulation. I don't understand "drying evenly" or what that means, or how it's done or what is supposed to come from it being done.TomC wrote:You should probably try to describe what you mean with real terms. Conductive moisture isn't a real or scientific term.
-Marshall Hance
Asheville, NC
Asheville, NC
Anything that has mass can conduct heat, outside of a vacuum. Heat being the relative term, not moisture. Does moisture leave the bean due to the heat applied? Yes. That's making the statement correctly. Semantics for the most part.
- cannonfodder
Have never roasted in a vacuum. The wife would probably yell at me for messing up her vacuum but chaff collection would not be an issue.
