Quest M3 Mods - Page 8
- FotonDrv
Assaf, when you "Doubled up on the holes" did you put them between the existing holes or add another row (staggered/offset) from the other row of existing holes?
- cuppajoe
Is the main reason for doing these drum and air intake mods primarily to facilitate lighter roasts?
Thanks
Thanks
David - LMWDP 448
- FotonDrv
Enlarging of the existing holes in the photo? What size (dia.) did you end up with?AssafL wrote:Increased the diameter....
TomC wrote:I love it.
OldmatefromOZ wrote:I am very happy with the modification.
Thanks for your replies! It seems quite clear cut. I'll look for a metal worker.AssafL wrote:Love it...
Without any modification there seems to be little airflow through the drum of the Quest. For many beans airflow seems to be important in light roasts and I guess it might matter for darker roasts too.cuppajoe wrote:Is the main reason for doing these drum and air intake mods primarily to facilitate lighter roasts?
By the way, this is a great forum. I'm quietly reading for some years now and learned a lot (at least I hope so).
Yes looks cool. I like the cheap and cheerful version of the holes around the last inch. I think I'll take my drum on my next visit to my dad who has more drill presses than he has kids.
LMWDP #603
- AssafL
5mm now. It was 3 prior. Remains to be seen that beans don't fall through.FotonDrv wrote:Enlarging of the existing holes in the photo? What size (dia.) did you end up with?
- FotonDrv
That was what I was thinking and I suspect it would depend on the beans you use. The peaberry size beans would be very different than a robusta.
Have you noticed that the holes add to/increase a better chaff collection?
I have considered removing Quest fan and using a variable speed vacuum with a cyclone chaff collector that all sits detached from the Quest and that would eliminate the maddening Quest Fan Cleaning hassle!
- AssafL
A vacuum would be nice. A dyson like cyclon would make a perfect accoutrement to the roaster.
My concern would be the heater power and heater lag (ceramic insulating ferrules make controlling the heater really lag prone). I have two halogen heating tubes I really wanted to stuff into the quest but they are too long. I wonder if they make shorter halogen tubes, it would make a nice upgrade.
- FotonDrv
I do not know what the CFM of the Quest fan is currently nor do I know what would be ideal, but this has a minimum of 50cfm to work properly.
http://www.oneida-air.com/inventoryD.as ... F1BB570002}
A variable speed vac will do that easily and I have one of these although the smaller model might be better.
https://www.festoolproducts.com/Festool ... fgodxqcH2A
This is the small model. https://www.festoolproducts.com/Festool ... fgod0_8LHg
