Quest M3 Mods - Page 2
- FotonDrv
That is a very new one and must be from a new batch being made. I wonder why they changed the setup??
- Bob_McBob
I was rather confused after unpacking an M3 I received from the factory today, so it's good to see I didn't get a random wonky "Friday afternoon" unit. My roaster is a brand new August 2013 production model, and the faceplate is reversed from all the other photos I've seen, just like Terence's. The drum rotates counterclockwise, so I assume this is an intentional design change. It looks like everything is perfectly mirrored, but I will have to find a diagram to check, so I know whether I need to worry about probe placement with the new revision.
Chris
- FotonDrv
My faceplate is on the original side configuration (Trier on left w/clockwise rotation) yet apparently the drum thickness is new style. Interesting. According to the "Data" plate mine was made "2012 11", which must mean Nov of 2012.
Terence, when was your made?
Bob, does yours have the .063" thickness metal for the drum?
- Bob_McBob
I can't get an accurate measurement right now, but it's almost certainly the thinner drum. I will take some photos of everything when the light is better tomorrow. I am assuming the front panel is just mirrored and the drum is reversed (including the fins) so I can safely install probes in all the standard locations, but I want to be certain before ordering parts from Eric.FotonDrv wrote:Bob, does yours have the .063" thickness metal for the drum?
What a weird version change
Chris
Mine is 2013 06. The drum rotates counter clockwise. I have thermocouples in the standard positions.
LMWDP #602
- TomC (original poster)
Very nice! I wish they'd provide one that was big enough in neck diameter to move beans thru easily, and just long enough to bypass the horizontal exhaust tube. It would be one less niggling task to take care of after dumping in the beans. I've searched online and the ones that look decent usually have too narrow of a neck to work right. Canning jar funnels are too wide in neck diameter. Ugghh..
Even with the 1.5" ID there is a slight bottle neck, the beans might stay caught up for less than half a second, but the effect is quite pleasing. Shows how wide the neck needs to be for there to be no delay.
LMWDP #602
- Italyhound
- FotonDrv
Nice funnel, you must have access to a sheet metal shop that can weld stainless!kwantfm wrote:I've now got a bean loading funnel for my Quest...
<image>
It's a 4" to 1.5" stainless steel reducer with 2" of 1.5" stainless steel pipe welded to it. Works very well!
Does that straight tube part extend past the cross heat return pipe/carry handle on Quest?
I made my funnel out of scrap in the shop and it is heavy but the beans slide down to the bottom of the load chute easily and sure makes loading Quest a snap. If I had a sheet metal shop around here I would use them for sure!!
