So, I've done a few minor mods to my M3, thinking about doing some additional ones. I know the mega mod thread is there and exists (I've made a pass through), but I was hoping to make and maintain a thread to either index posts there, or from other threads. In addition just to find out what is the current latest list of mods, and which ones do what exactly!
I'll try to just stick with functional mods, not ones done for looks. Also broken apart between mods and just accessories. So here's my first pass at it (in no particular order).
Modifications:
Insulation of drum - greater efficiency, larger charge sizes, gives up responsiveness for ability to "coast"
Paint/seasoning drum - greater efficiency, larger charge sizes, gives up responsiveness for ability to "coast"
Air intake pipe - introduces air mid-roaster instead of by default at the back. I suppose this pre-heats air better if drum is perforated at the back only?
Cut resistor - allows greater control over fan speed
Factory Perforated Drum - $100 + $35 shipping to USA
Hope this helps, I'm trying to decide what I'll be doing next, but likely either getting a perforated drum or drilling mine seems in the works. Thanks to the community for coming up with all this stuff!
Since I was indexing for myself to read again, it made sense to make it a post. If I forgot or missed anything that wasn't in the mega thread, let me know. Or if any explanation isn't correct let me know and I'll update the OP.
I've cut my resistor and seasoned my drum in the past. I think I'd like to try out a perforated drum, but I haven't decided the route to go...new drum or modifying old one.
I'd also really like to figure out a way to reverse the airflow. The exhaust fan I wish was on the intake so it wouldn't get so dirty.
Relative newbie here, but just rec'd my new Quest M3, and have seen wonderful handles/knobs that are posted on this thread. Would someone be kind enough to let me know who I might contact to have some made? Might as well start off 'looking good' w/the M3. Many thanks in advance....
goducks wrote:Relative newbie here, but just rec'd my new Quest M3, and have seen wonderful handles/knobs that are posted on this thread. Would someone be kind enough to let me know who I might contact to have some made? Might as well start off 'looking good' w/the M3. Many thanks in advance....
Stephen Sweeney made most of them. He posts under photodvr. Apologies for typos, I'm on mobile at the moment.
I've recently upgraded to a Quest M3s, and I am loving it. I'm also a 3d printer nut, so I couldn't help but make a couple of addons for the Quest. Here are links to the a charging funnel and a set of feet:
That funnel is really cool! I wish I had access to a 3D printer to try and make one. I use a canning jar funnel, taped to a cardboard tube from a paper towel roll. It works well and has a very large diameter throat, which was my main goal.
I printed a set of knobs for the M3s. This is a bit tricky, because most 3d filaments can't handle the temperatures involved. I'm currently using Proto-pasta's high temp carbon fiber PLA. This can be annealed after printing, which raises the temperature it deforms at significantly. So far it's holding up, but time will tell. I really like the look of the black CF knobs, so I hope they don't melt!
