Phidget vs Center 306
- CarefreeBuzzBuzz
Phidgets by far if you have a computer and don't need to see the temps on the device.
Faster sampling times; more reliable; less noisy.
Don't need a proprietary cable.
Roughly the phidget I looked at today was going to run me about $100
Are they hard to install?
- hankua
Instead of the Center meter, Mastech ms6514 is more affordable.
Center 306 has 2 channels. Phidget offers more if you want for air speed and heat level.
Hi Brent,bharmon91 wrote:Is one better than the other in regards to using artisan?
I see you have a fortis.
The fortis has a built-in holder for the Center. Do you have a center device already? If you already have a Center 301, you will just need specific cabling and associated drivers to connect to your computer and run Artisan. The update rate on the Center Display itself is more than "fast enough" IMO, but the signal passed to a computer is slower.
From reading posts on this forum regarding Phidgets, it seems straight forward and everyone seems happy with the update rate. Up front you will need to decide on Thermocouples vs RTD's, probe sizing, and probe holders/connections at the fortis.
HTH,
-LN
- CarefreeBuzzBuzz
Very easy to install.bharmon91 wrote:Roughly the phidget I looked at today was going to run me about $100
HOWEVER WHAT MOST PEOPLE FORGET - IS TO UPDATE THE FIRMWARE - instructions.
What are you trying to do and more advice can be given?
What do you want to measure?
If you don't have the Center to me the Phidget is the only way to go.
- Supporter ❤
I can only speak to phidgets. They are incredibly easy to set up. No issues at all and have been 100% reliable on my Mac. I even use their TCs.
I purchased the phidget temp sensor 4 input and the micro usb cable. Once they arrive I will be back at square one and won't have a clue what to do. This is all so new to me. I have the center 306 & the cord it came with, but I really want to use the roast master app on iOS which is why I purchased the phidget.
Have you looked here?
https://rainfroginc.com/documentation/s ... -phidgets/
