Panama Elida Natural Catuai - Klatch - Page 2
- CarefreeBuzzBuzz
Steve what grams did you start with?Brewzologist wrote:+1. That advice worked for me.
- Brewzologist
CarefreeBuzzBuzz wrote:Steve what grams did you start with?
18g using a Flair Pro2 manual lever. Alan clued me in to the 3:1 and really like it much better than 2:1.
EDIT: Also, using a ~15 sec pre-infusion followed by ~45 sec extraction that hits about 7 bar max.
- Almico
And grind a little finer. It can handle a 40s+ extraction.CarefreeBuzzBuzz wrote:I know Alan mentioned 1:3 for espresso; anyone else have thoughts on that?
- bradm
Mike, the sidebar shows 12.9% weight loss if I'm reading that correctly. Is that typical for you? I've been in the 14s with my "lighter" roasts... might need to change that.
- mkane (original poster)
Brad, seems to work. Interior bead color looks like exterior color. Just had a cup after waiting on ground beans for an hour. Drinkable as is, should be good after a few days. rest.
I'm not experienced enough to make a roast do what I want. I just let it do it's thing and see what happens. If R0R is declining and there's no flick/crash I'm happy.
- CarefreeBuzzBuzz
bradm wrote:Mike, the sidebar shows 12.9% weight loss if I'm reading that correctly. Is that typical for you? I've been in the 14s with my "lighter" roasts... might need to change that.
Don't understand 14s vs 12.9%?
- cmapes
14% range, like the "14's".CarefreeBuzzBuzz wrote: Don't understand 14s vs 12.9%?
fourteens for those of use who don't text. I'm going to try this again this am.
